12-20-2006, 02:32 PM | #21 |
RCC Addict Join Date: Jul 2006 Location: Johnston SC
just for record i hate you! this thing was already a blast but its gonna be just killer. ps you never ansered my question
12-20-2006, 02:55 PM | #22 |
Quarry Creeper Join Date: Jun 2005 Location: Northern CaliFOOLya
lookin good. why wk axles? to be diff or do u just like em that much more? i member the first ralph thread a while back. is it 1/4 tube or 1/4 rod? BIG J |
12-20-2006, 03:00 PM | #23 | |
RCC Addict Join Date: Jul 2005 Location: Provo
12-20-2006, 03:05 PM | #24 |
Rock Crawler Join Date: Nov 2004 Location: Lost in Florida
woooo! ralph 2.0 ... this is gunna be saweet i <3 your work JIA!
12-20-2006, 03:39 PM | #25 |
Rock Crawler Join Date: Sep 2004 Location: Santa Rosa
JIA- Did you pull those diffs from a Wheely King kit or did you source the parts to build them? If you sourced the parts, could you post up the required part numbers? I can't find a manual for the Wheely King on the HPI site. Thanks |
12-20-2006, 06:06 PM | #26 |
Quarry Creeper Join Date: Mar 2006 Location: TAOS NM
Bug off dudes !!!! me and JIA have agrements that if he sells ralf its mine.
12-20-2006, 07:20 PM | #27 | ||
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Could you PM me with price and turnaround time? I'm on a tight schedule. Looneybin...which question? IronOx, the WK axles are larger and beefier than TLT axles...and what better way to test'm that to put'm under my favorite basher? Quote:
I'll be old and gray by the time I'm ready to sell Ralph. Old anyway...I'm going bald much too fast to be gray at that point. | ||
12-20-2006, 07:32 PM | #28 |
how many hrs went into ralph v1.0?
12-20-2006, 07:51 PM | #29 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Was wondering if Ralphie was going to be the test bed for the WK axles When I saw the 4x4 submarine WK video I thought he was going to be the next step in the progression. Do you plan on using the WK trans as well? Very cool!!
12-20-2006, 08:00 PM | #30 |
Pebble Pounder Join Date: Apr 2006 Location: Anchorage
Cool, I've been waiting for the WK crawler build up. |
12-20-2006, 09:15 PM | #31 |
ScG, you'd have to ask rckjeep, he built Ralph's frame ages ago. Wildrice, this rig sees abuse on a weekly basis. Plans: WK axles TXT tranny Revo driveshafts Powered by Novak Crawler system Steering servo is a JR Sport 125MG DX3 All-Ts on RPM Revolvers It's the same basic stuff with the exception of the WK axles, Revo shafts, and the suspension links I'm making. Servo and battery placement will also change. I might have some build progress to post up later tonight. |
12-20-2006, 09:22 PM | #32 | |
RCC Addict Join Date: Dec 2004 Location: HELL.....
12-20-2006, 09:55 PM | #33 |
Bah! What's worse is my bin of ideas. Too many ideas, not enough materials or time. I started on the suspension links. Wanted to use a bit of a different setup on this one. I'm using 4-40 and 8-32 blind nuts and some 3/16" and 1/4" brake tubing to make the links. First thing I did was sand the finish off the flange on the 1/4 brake line. Also used a Dremel to take some finish off the blind nuts. Drilled the ID of the 1/4" line to 7/32" and slid the blind nut into the tubing. MIG welded the flange of the tubing and the blind nut together then brazed the joint. Ground down the excess material then put the link in the cordless drill. Sanded it with 120 grit to make it look presentable. End result is pictured below. I think it'll work so I'm off to make a few more. |
12-21-2006, 06:52 AM | #34 |
complicated but nice. looks sweet.
12-21-2006, 08:32 AM | #35 |
With the abuse you put poor old Ralph through, do you think those links will survive?...Doesn't sound like he's got any New Years resolutions to go on a diet. Clever Idea, and nice execution. |
12-21-2006, 09:28 AM | #36 |
Looneybin, The end result will be worth it. wildrice, The way I'm building these links they'll be plenty beefy. I still have more more steel to add. With the suspension I'm putting in a conventional link just won't work. I figured this was the best way to get the job done. Last edited by JasonInAugusta; 12-21-2006 at 09:44 AM. |
12-21-2006, 11:11 AM | #37 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
JIA PM sent. Love the links. |
12-21-2006, 11:48 AM | #38 | |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
Interesting idea about the links, I like it. So the majority of the inside of the link is hollow? | |
12-21-2006, 07:10 PM | #39 |
Yeah, basically the entire link is hollow. (I know what you're thinking and it won't be weak. ) I wanted to have more progress pic but I set the MIG wrong and burned through one of the 3/16" tubes. That wouldn't have been so bad, but there was threaded rod under the area I burned through. The rod wouldn't come out so I'll have to cut the tube and screw. Once I noticed this I left things on the bench and cooled off. I'll try to post up more pics of the build later tonight. |
12-21-2006, 07:25 PM | #40 | |
Seriously though, I like the idea and I really would like to know how it works out. I don't know anything about the tubes aside from I can bend and braze them. How do you make a flange on the other side of the tube? | |
