12-21-2006, 07:28 PM | #41 |
06 Super National Champ Join Date: Jun 2004 Location: Stark Industries Bar and Grill
Just get a flaring tool. I'll try to get a pic of the completed front end tonight. It'll all make sense then. Last edited by JasonInAugusta; 12-21-2006 at 07:32 PM. |
12-21-2006, 07:46 PM | #42 |
Rock Crawler Join Date: May 2005 Location: omaha
| ! !Pure blasphemy!!:sho ck: Using one of my wheels to hold Ralphs *ss off the ground Looks like you have some real cool ideas for the build, keep the pics coming. |
12-21-2006, 08:10 PM | #43 | |
You should see my paperweights. | |
12-21-2006, 08:18 PM | #44 |
I wanna be Dave Join Date: Sep 2005 Location: *
I have used hollow carbon shafts and never had a durability problem the steel ones should work fine. Great idea on the flaring of the tubing it looks saweet.
12-21-2006, 08:22 PM | #45 |
would take forever to do, but threading the threaded rod all the way through would make the links plenty beefy i would think?
12-21-2006, 08:48 PM | #46 | |
Quarry Creeper Join Date: Mar 2006 Location: TAOS NM
12-21-2006, 10:43 PM | #47 |
Rock Crawler Join Date: Aug 2006 Location: On the trail
damn very good job!!!! |
12-21-2006, 10:45 PM | #48 |
Here's the near complete link assembly. Lowers are the regular aluminum links that have been used on Ralph for ages. The uppers are the crap I've been working on. Basically they're a larger version of the stock Wheely King upper link. The center section is made from 3/16" brake tubing with the 4-40 blind nut welded and brazed in place. This is what attaches the "V" of the link to the axle. A 4-40 screw passes through the upper link mount and threads into the center of the "V". The two outer links are the 1/4" brake tubing with 8-32 blind nuts welded and brazed in place. Sections of 8-32 threaded rod and some Kyosho 6.8mm ball ends with flanged balls complete the upper links. More steel will be added shortly. Last edited by JasonInAugusta; 12-21-2006 at 11:01 PM. |
12-21-2006, 10:54 PM | #49 |
Pebble Pounder Join Date: Sep 2004 Location: Livermore, CA
Is there a reason why you opt for U link rather the 4 link?
12-21-2006, 10:59 PM | #50 |
The Wheely King axles use this config in stock form. I decided to carry this over to Ralph instead of making a bunch of aluminum bits to mount a conventional 4-link. An advantage to doing it this way is that the Wheely King axles stay, for the most part, intact. I also have no detectable axle steer. |
12-21-2006, 11:32 PM | #51 |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
Very cool JIA. I learned something new with the flared ends. I might have to pick me one of those up, I like how it looks. Granted, I suck at measuring it in the first place, so they're always short or long anyway. Pretty ends won't make mine look any better. heh I really like those triangulated 3 link uppers like that. You're right, that will be very solid. |
12-22-2006, 12:13 AM | #52 |
It's stout right now but to make strong enough for Ralph I'll beef it up a bit.
12-22-2006, 12:23 PM | #53 | |
12-22-2006, 07:25 PM | #54 |
Just one on the wide end. Since the upper links remain stationary in relation to one another I'll cut some sheet steel and make an electronics shelf that will be welded/brazed to the upper links. Between the cross brace and sheet steel it'll be stout. |
12-22-2006, 07:59 PM | #55 | |
I wanna be Dave Join Date: Dec 2005 Location: Orlando
12-22-2006, 08:42 PM | #56 |
Pebble Pounder Join Date: Oct 2006 Location: Enterprise
Hey JIA, What are you using to attach the shocks? Or are you attaching them to the axles? I'm just curious cause I'm re-doing the rear four link on my Gecko 2 to give it a 16.5 inch wheelbase and was wondering what I should use to attach the shocks. Sorry for the hijack. |
12-22-2006, 09:04 PM | #57 | |
Probably near 10lbs like normal. krawlinCJ, The shocks are mounted to the axles using stock link/shock mounts but rotated. | |
12-23-2006, 11:29 PM | #58 |
No progress on the rig tonight. Went to a buddy's house to help him with Christmas presents for his kids. My Whitebone showed up today. Stuck Ralph on the trailer and watched the trailer tires squat a bit. Tomorrow should be a short work day, that means more time to build! As of now the front is completely done, just need to add the steering servo. |
12-23-2006, 11:33 PM | #59 |
RCC Addict Join Date: Jan 2005 Location: Green River Kentucky
Quit flapping your gums and go finish it allready JEEZ |
12-23-2006, 11:37 PM | #60 |
he-he JB, you need to come down to Augusta in Jan. |
