Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > HPI Wheely King
Thread: My crawler king in progress
Old 03-26-2016, 02:06 PM   #1
Default My crawler king in progress
So here's where I'm at so far. Try ed the level 3 drop, no go. I went back to stock with to mount. Added the high steering knuckles that are designed for the track conversion. Worked pretty good. Had to imagine er a few parts while I'm waiting on more parts to come. So far so good. Modified some integy 3 link mounts to run my 4 link setup. Had to run the top links to the outside of the frame but all seems to work just as well as it did before. Wanted to run it a bit before I finalized everthing. Running some really soft springs on the rear, which after much research, found out that was wrong but boy does it flex and crawl well this way. May not be comp worthy but it's fun on my course and anything else I want to crawl.
Sent from my SM-G900V using Tapatalk
thebuilder is offline   Reply With Quote
Old 03-26-2016, 06:57 PM   #2
Default Re: My crawler king in progress
Update:
Got bored so I played with some springs today.
RR: 1.14 main spring, 1/2 of the stock spring on top.
LR:1.01 main spring, 1/4 stock spring on top.
FR:0.9 main spring, 1/4 stock spring on top.
FL: 0.9 main spring, 1/4 stock spring on top.
Almost solves all the body roll/torque twist these cralwers have. Next I want to mess around with fluid since I'm sure these stock shock have leaked out at least 5% of the original fluid,lol. Plans are to upgrade to some aluminum shocks eventually just haven't decided which ones and which lengths yet.
Old 03-26-2016, 06:59 PM   #3
My crawler king in progress - Similar Threads
Axial Deadbolt - First Crawler Progress Ahod39 Axial SCX-10 0 11-09-2015 07:37 PM
Crawler Course in progress, Manheim, PA CAPTAIN INSANE-O General Scale Talk 19 09-19-2010 06:43 PM
First crawler in progress, a few questions. ComingApart Newbie General 6 03-07-2007 08:24 PM
JMan's crawler help/progress thread... JMan8108 Tamiya TLT Crawlers 0 06-24-2005 08:03 PM
