![]() | #1 |
Pebble Pounder Join Date: May 2004
I snapped my wheel shaft part # Ma056 (spindle) Does anyone know if the Mad Force wheel shaft works? The bearings are the same size. The only difference I see is that the MF uses a bolt to hold the wheel on. The TF uses a nut on the threaded part of the spindle which is longer. I brazed the pieces together. It lasted about a half a battery pack. |
![]() | #2 |
Pebble Pounder ![]() Join Date: Jul 2004 Location: Quakertown PA
Did you break it like this? Hollow stub axles??? I bought the Savage parts but I did have to turn down the back side of the cup so it would stick through enough to get the pin through the axle. The savage axles are also a smaller dia. to go through the wheel. I ran one charge on it and havent had a problem so far though.
![]() | #3 |
I broke it the same way. I used the spindle,pin and hex from my Savage. That way I did'nt have tomodify anything.
