04-20-2012, 02:55 PM | #101 |
Quarry Creeper Join Date: Jul 2011 Location: olympia
| Re: starting another 1/6th Willys
bummer on the 550 with the gru, it all fit in there really nice and it was cool to see something a bit different....very nice chassis work by the way |
04-20-2012, 05:21 PM | #102 | |
| Re: starting another 1/6th Willys Quote:
This motor I'm trying could just be a voltage issue- it was rated to run at 12V-18V, the 3s LiPo is a bit short on the voltage for this motor. I don't have any 4s packs or a ESC that can handle 4s so I have no way of testing. Last edited by BigSki; 04-20-2012 at 09:59 PM. | |
04-20-2012, 09:55 PM | #103 |
I got to looking at the Hennkwell motor that came w/ the GRU and compared it to the Johnson Industries 550 drill motor that I had on hand. I swapped the pinions and put the JI motor on to the GRU and put it back in the Jeep- Holy Crap! The Jeep is almost stupid fast now, at least as fast as a stock Honcho. I don't know how to accurately describe the increase in power and speed, it's just a HUGE difference. I'll drive it the yard tomorrow to get a real feel for it, but now I'm thinking I'm gonna have to slow it down a bit, maybe run on a 2s or drop the UD gears back into the axles. |
04-24-2012, 06:48 PM | #104 |
Pebble Pounder Join Date: Dec 2011 Location: san diego
Great build, those leafs will work just fine once all the weight is applied. Oh and not a big fan of the Navy blue. I think I have apic of my grandpa in that jeep |
04-24-2012, 07:57 PM | #105 |
| Re: starting another 1/6th Willys |
04-24-2012, 08:07 PM | #106 |
I was encouraged by someone on scale4x4rc to do a better job on the steering. I knew in my heart that the CMS style setup that I made was just an easy cop out, but I wasn't sure how to get the steering to look like the old bell crank setup, until last weekend. I was at a buddies house running the orange Jeep in the ravine on his property. He gave me a purple aluminum bell crank upgrade for a WK, I knew I could make it work on the blue Jeep. The bell crank has two small bearings in it. I took a piece of 1/4" solid rod, counter bored a #40 hole then tapped it for M3. I "frenched" in the steering arm mount into the round cross member and brazed it together. Once I sand blast it clean and paint it, it should look the way I wanted it to. I just finished this tonight, I need to dial in the drag link length and get a better servo horn, but I'm on the right track. It looks much more like the Willys style steering system and this seems to function better on the model compared to the first attempt at the steering. Last edited by BigSki; 04-24-2012 at 08:40 PM. |
05-14-2012, 08:34 PM | #107 |
I needed to get started on a windshield frame for the body but I wasn't too sure on the best way to accomplish this, I didn't want to spend a bunch of time making a completely scratch built part that would be fragile, I'm positive that this Jeep will end up on the roof more than once. I found my answer when I made a scale drawing of a CJ3A windshield frame on some velum then held that drawing over top of the stock frame, the stock frame was close enough to the correct size that I knew I could make it work. I carefully cut out the folding windshield section, then heated the remaining frame with a heat gun and gently reshaped the top section of the frame. I then put some carbon paper between the velum and a piece of styrene, tracing out the design which left a carbon copy of the design on the stryene. I cut that out and epoxied it to the stock frame. It's drying right now so I won't know until tomorrow if it's gonna work but I think it will be ok. Last edited by BigSki; 05-14-2012 at 08:51 PM. |
05-15-2012, 08:20 AM | #108 |
I wanna be Dave Join Date: Oct 2006 Location: Martinsburg WV
Damn that body is looking good!!! All the detail work is really worth it. Nice job on the bellcrank. That is good thinking (all the work I did moving the servo here and there trying to get it right, I'm smackin' myself in the forehead right now) If you can spot that in the right spot it opens up so many options for mounting the servo itself. Outstanding. Hell the whole chassis is good thinking dude! I really want to see this one for myself when its complete... We still need to run these Jeeps somewhere nearby both of us now that summer is back. Like Sugarloaf Mt. or Gambrill, someplace around there I'm sure we can find some good spots to shoot some video... Last edited by Big Mike; 05-15-2012 at 08:24 AM. |
05-16-2012, 09:52 AM | #109 |
RCC Addict Join Date: Nov 2007 Location: Massachusetts
Your windshield frame looks great so far Walter Did you still need me to snap a few pics of my 1:1's frame from the backside ? ( drivers perspective) I can't wait to see this one finished..!
05-16-2012, 05:22 PM | #110 | |
I found a source for 26mm diameter glass optical lenses that look like headlights, I'll post a pic when they arrive. Last edited by BigSki; 05-16-2012 at 05:25 PM. | |
05-18-2012, 11:10 AM | #111 |
RCC Addict Join Date: May 2008 Location: Green Bay
Lookin awesome Big, love it all. Quick question for you. How wide is your frame/chassis (outside-outside) ? I can not get a decent measurement off of the one I made, yours looks more on the stock scale side then mine. Be sure to post up those lenses as well. |
05-18-2012, 12:13 PM | #112 |
RCP CRAWLERS Join Date: Nov 2007 Location: Upland CA
amazing ....love the leaf spring set up and custom frame work
05-18-2012, 05:27 PM | #113 | |
Thanks Dave. The front leafs are proving to be a huge PIA, the shackles get snagged on rocks way too much for my liking. I'm seriously considering reworking the front end to have the shackles on the rear of the springs and then a u-bolt flip, those pesky u-bolts keep getting snagged on everything. After a small amount of running the blue Jeep, I can honestly say that the leaf spring setup is more of a visual treat, the performance just isn't there. I'll be hanging on to the orange Jeep for a long time, it's much more capable on the trails then this blue Jeep will ever be, | |
05-19-2012, 11:30 AM | #114 |
4.6, thank you very much. I thought mine was off a bit. I got 4.75" on mine.
05-19-2012, 03:50 PM | #115 |
RCC Addict Join Date: May 2010 Location: Midwest
That bell crank setup is killer I just ordered an aluminum bell crank. I'm thinking about mounting the bell crank to the axle. Do you think that would virtually eliminate torque steer/bump steer? Last edited by Die-Laughing; 05-19-2012 at 04:02 PM. |
05-19-2012, 10:26 PM | #116 | |
I've found that the best way to keep bump steer at a minimum is to have the drag link parallel to the ground when the vehicle has it's full weight on the tires. (static ride height) | |
06-13-2012, 07:19 PM | #117 |
Almost another month and nothing was getting done until today. I've been making myself slowly get back to work on this thing. I got a driver off of fleabay 2 weeks ago for $14 shipped, he finally showed up for work! The first thing I needed to do was to set the seat height. I have a set of those beautiful aluminum seats from Norm @ Team 3 six . I'm still not 100% I'm going to use these seats, but for now I could at least get started on a seat frame so that I can orientate the driver then start bending some roll cage tubing around him. I also need to find a better epoxy for the windshield frame, my attempt to make styrene stick to the injected molded plastic failed miserably. Last edited by BigSki; 06-13-2012 at 08:03 PM. |
06-26-2012, 08:22 PM | #118 |
progress is slow right now, here's a little update on the cage. I wanted something different from the one that is in the orange Jeep. Now I need to start making some triangulating for strength. It's taken a year of practice but I'm finally getting very comfortable w/ my brazing skills, the joints just look cleaner than anything else I've done. I can even get the bronze 'wet' and make it flow where I want it to go. Last edited by BigSki; 06-26-2012 at 08:40 PM. |
07-04-2012, 07:44 PM | #119 |
The cage is finished, as far as the fab goes. I shot it in etching primer today, I'll let it cure for a day then spray it in a color. I'm thinking about using something besides satin black, any suggestions? Next up is the seats. I've decided against the aluminum seats I mocked up earlier. I realized that they aren't 1/6th scale so they aren't going to do it. I can either use some seats from a Nylint Jeep or fab something out of styrene and brass. Last edited by BigSki; 07-04-2012 at 08:07 PM. |
07-05-2012, 07:59 AM | #120 |
Pebble Pounder Join Date: Nov 2010 Location: Northern NJ
I think the gray compliments the light blue body. I would do all the trim and details in gray.
