10-25-2012, 07:34 AM | #21 |
Pebble Pounder Join Date: Jan 2012 Location: Chino Hills
| Re: What Motor, ESC and Gearing are you using on your Jeep Willys?
Playing around with different pinion gears did not really work. So I put the 8T pinion back. I also bought the 75.1 T1 transfer case and swapped it with the one I have. The Jeep is now running in a lot more higher speed than before. Faster than walking speed but not as fast as a Wraith.
11-04-2012, 08:58 AM | #22 |
Just an update. I have ran 3 battery packs and she is still running good. The R2 transmission is sill holding on as well as my temporary Axial AE-2 ESC. I had a loose screw in my right axles that I needed to tighten up but that's it. Fan is keeping everything cool but then again it has not been that hot here in Cali.
04-21-2013, 12:00 PM | #23 |
I finally broke down and became a member just so I can post pictures. Here are the pics of my build. So far she is running really good and no issues at all.
04-27-2013, 11:10 PM | #24 |
Newbie Join Date: Nov 2012 Location: maple ridge, BC
I have a scx10 tranny with 27 turn motor with stock spur and pinion. Then through a wheely ki g transfer case pretty good crawl and speed
What Motor, ESC and Gearing are you using on your Jeep Willys? - Similar Threads | ||||
Choosing a motor and ESC for your Wraith - Gearing Added! | Harley | Axial Wraith | 2065 | 05-06-2022 01:02 PM |
Motor esc gearing combo check | Vesteroid | Axial Wraith | 2 | 01-03-2012 03:27 PM |
esc motor gearing ect help | corvair wally | Electronics | 5 | 12-09-2010 11:46 AM |
Gearing Question,HH motor,FXR ESC.Need gears Now | WrenchHead | Losi Mini-Rock Crawler | 1 | 04-21-2009 08:02 PM |
Will this combo be bad (esc, motor and gearing) | hpi123 | Electronics | 2 | 12-14-2007 04:27 AM |
