01-09-2012, 03:40 PM | #1 |
Rock Stacker Join Date: Jan 2012 Location: uk
| rookie suspension mod
hay guys, iv done my own suspension mod today, iv mounted the shocks inboard on the chassis, iv also lowerd them to the 2nd hole down. i used 6mm bar to make the brace, 3mm screws either side, then drilled and tapped the bar for the 2.5mm thread of the ball stud! its not perfect, and i found that i needed to add springs to the rear because it wasnt returning perfectly striaght! i want to make some custom tie rods, so that i can have better wheel clearance on the front (lock to lock) and also some new lower links to help prevent botteming out so easy! |
01-09-2012, 05:30 PM | #2 |
Newbie Join Date: Aug 2006 Location: Indianapolis
| Re: rookie suspension mod
Nicely done! Did it help the performance?
01-10-2012, 01:22 PM | #3 |
Yea performance is loads better! About half an inch maybe (13) perhaps a little more articulation by my calculations any way! Adding springs has slowed down the articulation rate, which has stopped it flipping on its roof when the front flips up!
01-10-2012, 08:36 PM | #4 |
Quarry Creeper Join Date: Jul 2011 Location: olympia
came out nice... i did the same kinda thing with the shocks on the quad build im doing... performs better for sure...
rookie suspension mod - Similar Threads | ||||
free suspension mod | rider12693 | Axial AX-10 Scorpion | 12 | 10-21-2008 01:53 AM |
suspension mod idea | bluto | General Crawlers | 4 | 06-15-2007 12:59 PM |
Easy suspension mod | JEEPTJ | General Crawlers | 12 | 04-20-2006 09:34 AM |
Suspension mod #2 (plus more) | rerock | General Crawlers | 6 | 10-14-2005 03:03 PM |
MY suspension articulation mod | xtremecrawler504 | General Crawlers | 4 | 09-19-2005 11:12 AM |
