11-26-2012, 10:37 PM | #41 | ||
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
| Re: Micro Wraith Axles Quote:
Thanks Slam! Quote:
3s is king I highly recommend it! The mrc drive lines are bullet proof no problems at all..... I had a problem with my t-case input shaft rounding out the D shape in the gear, so I got lucky & had the part needed for the sumo t-case mod.. For this mod you will need: 1 12t 48p losi pinion / part# LOS4112 Dremel, drill & file or a lathe 1/8 music wire 5/16 dill bit or step bit The pics will tell the story Old shaft on the bottom, new one is solid Gear mesh is perfect even though the stock sumo gear is a 13t First shot didn't have the pinion depth set right so I killed the center gear in under 10 seconds.. This is when the idea & mini lathe kicked in, sunk the pinion down & it was good to go! I will test it out over the next few days & report back as to if it held up to the parts snap'n power of the Chev. | ||
11-26-2012, 11:16 PM | #42 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
Awesome! I'm definately doing this to my tcase!
12-05-2012, 06:39 AM | #43 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
How did you clock the knuckles, and how was the T-case mod completed? Details please, I have two Sumo's and a lathe... |
12-06-2012, 11:00 AM | #44 |
Thanks MK, if you are going to run mad powa this is a must do on the sumo case @KnutKase Clock'n the C's are easy, grind down the 4 locater nubs on the case & redrill the holes when you got your knuckle clocked to where you want it. On the case you just have to drill the back out to 5/16 so the pinion will fit...Take the 1/8 rod & file 2 flat spots, one on each end for the grub screws....I had to turn the blank space on the gear down some to get it to fit in the hole without hitting the center case screws...Then it was just a matter of getting the pinion set to the right depth & tightening down the grubs |
03-15-2013, 09:46 AM | #45 |
Rock Crawler Join Date: Jan 2013 Location: Laguna Niguel
Sorry for the thread revival but this is so awesome! Any updates on this project.
