01-17-2012, 10:34 PM | #1 |
Rock Crawler Join Date: Nov 2008 Location: Nor*Cal Cameronpark
| SilveradoSlinger on stretched sumo's update!
Something I have been messing with over the weekend. Micro Wraith Axle: L/R stock losi, stock sumo & the MWA sumofied: Last edited by chevy55; 10-26-2012 at 10:54 PM. Reason: Title change. |
01-17-2012, 10:46 PM | #2 |
Rock Crawler Join Date: Sep 2005 Location: Duncan, BC, Canada
| Re: ------mwa------
oh no you didn't! that is just stupendous! ... wonder what it would take to do it to a Losi axle? is the Losi axleshaft drilled and pinned (literally)? Last edited by Rockfrog; 01-18-2012 at 02:32 AM. |
01-18-2012, 02:09 AM | #3 |
Pebble Pounder Join Date: Nov 2011 Location: Oahu
| Re: ------mwa------
dam those are some nice axles! paint um black and make a scaler... please nanana but nice work!
01-18-2012, 04:34 AM | #4 |
Pebble Pounder Join Date: Nov 2010 Location: centereach
| Re: ------mwa------
i like where your heads at. forget trying to get your hand on some wideners. just widen the axles. post up some infor about what is needed. good job keep up the good work |
01-18-2012, 06:40 AM | #5 |
Rock Crawler Join Date: Oct 2011 Location: minot
| Re: ------mwa------
Ahhhhhh U BEAT ME TO IT!!! I've got axles ON ORDER and brass out the wazooooo, was gonna keep the diff centered tho.. I HATE barrel nuts! |
01-18-2012, 07:58 AM | #6 |
Rock Crawler Join Date: Oct 2011 Location: Lexington
| Re: ------mwa------
How come nobody makes this stuff to sell? Seriously, wouldn't a ton of people buy these? Looks awesome, looks like the Sumo axle is a little tougher, though the diff is pretty big. |
01-18-2012, 08:08 AM | #7 |
RCC Addict Join Date: Jun 2007 Location: MESA
| Re: ------mwa------
That ROCKS! I know what my next project will be! You know copying is the highest form of flattery. In other words...I'm gunna copy!!! |
01-18-2012, 09:08 AM | #8 |
| Re: ------mwa------
I've already started ... brass 9/32" tube (.014" wall) is a perfect slip fit on the Losi axle case ends ... but I didn't have any other sizes that would work for an inner and outer re-inforcement (I plan to add that bit of extra as I''m gonna try and extent the Losi axle) ... I see another trip to the hobby store in my future.
01-18-2012, 09:48 AM | #9 | |||||||
| Re: ------mwa------ Quote:
Only broke one microscopic drill bit Quote:
Info below Quote:
& I agree barrel nuts! Quote:
Parts: 9/32 brass tube- K&S part # 132 1/4 brass tube K&S # 131 1/8 brass tube K&S # 1154 3/32 brass tube K&S# 812 set of losi axles LOSB 1712 Drill bit to drill out the 3/32 tube for the axle shaft to fit...I have no clue what size the bit is, no markings on it & package it came in is long gone. Before drilling the 3/32 tube out sleeve it with the 1/8 to keep it from bending as the wall of the 3/32 becomes quite thin. Last edited by chevy55; 01-18-2012 at 09:54 AM. | |||||||
01-18-2012, 09:59 AM | #10 |
| Re: ------mwa------
Awesome, thanks for the info ... I might even have a bunch of that tubing already at home, and I got axleshafts to spare. Just had a thought - I'll check, but Mini-Qlo axles might be able to be used and negate the need to lenghten the stock shafts. I know they use the same bearing at the outers and the outers fit the stock knuckles, the inners are similar but beefier ... just need to look at the worm end of things. I can see my MOA v1 getting pillaged shortly Last edited by Rockfrog; 01-18-2012 at 10:21 AM. |
01-18-2012, 12:56 PM | #11 |
Newbie Join Date: Jan 2012 Location: wilsonville
| Re: ------mwa------
That is awesome!!! But where did you get those tires and the motor?
01-18-2012, 05:12 PM | #12 |
Rock Crawler Join Date: Dec 2010 Location: Madison Co.,Ms.
| Re: ------mwa------
Nice work Chevy55. Very cool. You have singlehandedly eliminated the most annoying trait of widening with spacers....scrub radius. That is exactly what will throw your front end off a line when even making minor steering adjustments. Good job....as usual! Good to see you back here. |
01-20-2012, 10:31 PM | #13 | ||
Tires are from the mini Qlo, motor is from greatplanes its the elctrifly Ammo 20-30-2650kv. Quote:
I started on the link mounts & truss but I just didn't like the direction they were going..To big & bulky: Here is the start of version 2. way leaner looking but they will weight more than the older version | ||
01-21-2012, 08:57 AM | #14 |
| Re: ------mwa------
Bad ace.
01-22-2012, 10:06 PM | #15 |
| Re: Micro Wraith Axles
Thanks E! Got them done minus file work & some paint. Ditched the lockouts & opted for 4 wheel steer. Next to a stock losi For size comp.: Next to stock sumo's on the dirt pro mudder: Next to the Danally rim modded S-10 on losi axles: Now I got to figure out what to put em under? Last edited by chevy55; 01-22-2012 at 10:08 PM. |
01-22-2012, 11:13 PM | #16 |
Nice work! Those are a great size, super class micros!
01-22-2012, 11:58 PM | #17 | |
| Re: Micro Wraith Axles Quote:
01-23-2012, 12:29 AM | #18 |
RCC Addict Join Date: Jun 2010 Location: Australia NSW
hey chevy how do they compare width wise to QLO? with widenend wheels. |
02-08-2012, 05:34 PM | #19 |
u ever get these mounted?
02-08-2012, 06:02 PM | #20 |
Rock Crawler Join Date: Oct 2004 Location: The thumb
I think i may have seen a sneek peak of what they will go under last night in a PM. Be prepared everyone!!!
