Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: Anyone cut there trekker chassis down?
Old 11-01-2012, 06:32 AM   #1
Default Anyone cut there trekker chassis down?
Was thinking about cutting the chassis just in front of the shock mounts.
Is there gonna be any disadvantages to this other than not being able to mount the body on?
MudHead is offline   Reply With Quote
Old 11-01-2012, 05:35 PM   #2
Default Re: Anyone cut there trekker chassis down?
If you want a shorter chassis, just pick up an McRC chassis. You will lose some rigidity in the front as well because the front brace will disappear. The McRC chassis is steel so it won't flex.
8695Beaters is offline   Reply With Quote
Old 11-01-2012, 06:46 PM   #3
Good point. I wasn't wanting to shorten the chassis just wanted to relocate the battery to the front. With the stock chassis there isn't enough clearance to mount it on the servo.
Old 11-01-2012, 09:13 PM   #4
A smaller battery would help. Good time to upgrade to a Li-Po!
Old 11-02-2012, 06:07 AM   #5
I'll try the Li-Po first before changing the chassis. Thank ya sir.
Old 11-02-2012, 04:53 PM   #6
I have never cut my frame, however, I did drill a bunch of holes in it. It seemed to help some. I only drilled the highest rail and left the lowers alone.
LavaCapCrawling is offline   Reply With Quote
Old 11-02-2012, 05:05 PM   #7
and here I just got rid of my losi Micro rockcrawler chassis plates in leu of a custom chassis.
Intashu is offline   Reply With Quote
Old 11-02-2012, 05:15 PM   #8
i have crawler chassis plates if you are interested in them
Mastah Kyler is offline   Reply With Quote
Old 10-11-2013, 10:53 PM   #9
Drc
I found the delrin chassis from the toyz pretty good on my micro crawler. Got a trail trekker coming in almost bought one for it, until I thought it wont be enough this time.hehehe
Drc is offline   Reply With Quote
Old 10-13-2013, 06:19 PM   #10
Just tried a Lipo on my McRC w/90t from Danally and am very impressed! Crawling performance is now worlds above the factory NiMh set up. Also widened the rims, changed the springs, moved the electronics/battery and added some lead on the axles.
Ordered a set of chassis plates for my Trekker because I'm gonna cut the top rails back and don't think the slight loss of rigidity will be noticable on such a lightweight set up. Can always add a small crossmember if needed. Maybe can just bend the top rails in and tie them together with a bolt/nut or two.
Working on some larger tires, for the small factory rims, to gain some ground clearance/approach angle since I seem to have gotten in on the Micro Crawler scene too late to get Miclows. Don't really want to have the monster size mini wheels on my Micro.
anuthabubba is offline   Reply With Quote
Old 10-13-2013, 08:48 PM   #11
I joined the Band!
yes lipo and 90t make a world of difference.... then you did all the others.. well played....
larger tires? like? I have boggers/claws/MiClaws and all are great for their purpose....
RootBreaker is offline   Reply With Quote
Old 10-13-2013, 08:58 PM   #12
Have some Super Swampers ordered. Clipped every other lug on the OEM ATs and got good results over the Losi Claws. Would like to have some of the sticky Losi Claws that were taller. Haven't found any Miclaws yet.
Old 10-13-2013, 08:59 PM   #13
I joined the Band!
Originally Posted by anuthabubba View Post
.... Haven't found any Miclaws yet.
good luck on that one... let us know when you do.. and after you buy yours ..
Anyone cut there trekker chassis down? - Similar Threads
anyone raise the lower links and cut the chassis Jcplante Redcat Crawlers 8 08-26-2011 02:00 PM
Question for Trekker (or Trekker suspension link) owners Markhpnc Losi Micro-Rock Crawler 9 08-12-2011 05:43 PM
Trekker with DP Torsion Chassis Evilinside Losi Micro-Rock Crawler 1 05-16-2011 07:13 PM
Which tools to cut stainless chassis? racecarking123 Tools, and Procedures 13 07-03-2005 04:23 AM
