Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Micro-Rock Crawler
Thread: fix/maybe pinion mod
Old 01-22-2013, 02:24 PM   #1
Default fix/maybe pinion mod
well i'm honored to tell you guy I stripped my first pinion
most likely from all the extra torque after locking the slipper!
so i grabbed me some of this stuff from my Pops stuff
for my new pinion i used the smaller end of this metal gear from a burnt servo that i dipped in water and didn't waterproof the small end was the stock 10 tooth and i just drilled out the hole in the gear alittle and mucked some of that stuff in and let it cure overnight.
i tested it---> put the tires in holes on my rock crawl course and flipped the truck and just used up a lipo full powering it and crawling ....now just to see how long my metal pinion holds
oahuzuki is offline   Reply With Quote
Old 01-22-2013, 03:11 PM   #2
Default Re: fix/maybe pinion mod
I've been using these: Pinions (the small gears) Radical RC A perfect press fit and you can get 9T. And at $1.75, they're a steal.
8695Beaters is offline   Reply With Quote
Old 01-22-2013, 03:48 PM   #3
im going to order one of those for sure! thanks. can you notice a difference between 10 and 9?
Old 01-22-2013, 06:19 PM   #4
Ohhhhhhhhh yes. You can hear the motor spinning a lot faster and you definitely notice the added torque, especially if you're using a big spur.
Old 01-23-2013, 07:30 AM   #5
I should add that it is a TIGHT press fit onto the motor shaft. Use a vice or a clamp to get it on. I used a rubber mallet and broke my motor case (hooray superglue!!!). And make sure you're happy with the tooth count...I've never tried to remove mine, but considering how hard it was to get on, I'm not sure how easily they will come back off. Either way, a great bang for the buck, and they work perfectly.
fix/maybe pinion mod - Similar Threads
mod 1 pinion gears.......... bob1961 General Crawlers 2 10-14-2010 04:12 PM
How to mod the t-case for a smaller pinion? DaSamurai Losi Mini-Rock Crawler 4 09-09-2009 08:04 AM
pinion mod drizzt Newbie General 0 08-06-2008 12:00 PM
tlt 1 ring and pinion fix eitmhl Tamiya TLT Crawlers 6 01-15-2006 09:14 PM
Cheap fix / mod sticky in Gen Crawl.... BENDER Comments, Suggestions, and Help 9 01-14-2005 05:27 AM
