01-22-2014, 11:46 PM | #1 |
Rock Stacker Join Date: Jan 2008 Location: Victoria BC
| 2mm Rod ends
I dont want to run the ball stud links, and they've been swapped on mine anyways. I need to redo the links, and have been trying to find 2mm ends that arent $10/pair and neon orange and found these... https://www.hobbyking.com/hobbyking/...0pcs_set_.html Anyone used them? Or have another alternative? Up until now the only thing I could find where the Dubro ones. Last edited by spidr; 01-23-2014 at 12:01 AM. |
01-23-2014, 07:11 AM | #2 |
Quarry Creeper Join Date: Jan 2013 Location: LP, LA
| Re: 2mm Rod ends
Great Planes makes some with hexagonal bodies you can use a small wrench on. Same color as the DuBro ones.
2mm Rod ends - Similar Threads | ||||
2-56 rod and mini t rod ends + few other questions | seven | Losi Micro-Rock Crawler | 11 | 03-14-2016 08:33 PM |
will jato rod ends fix my ti rod problem? | J-Fish | Axial XR10 | 8 | 03-19-2013 06:56 PM |
Drilling Holes into Delrin rod for rod ends | FDAapproved | Losi Mini-Rock Crawler | 10 | 02-13-2009 03:44 PM |
