01-11-2015, 05:51 PM | #1 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Gearing Question
Hey guys is it worth buying a 58 or 59 tooth spur gear to add a little torque to a stock running losi , I have two DDT 100T but with the stock tires its way to slow. Any info would be much appreciated.
01-11-2015, 07:01 PM | #2 |
RCC Addict Join Date: Jun 2007 Location: MESA
| Re: Gearing Question
If the motors are too slow a 58 or 59 are the wrong way to go. They will slow it down even more. The only way to get speed and low end control is a stroker at a 50 turn or so. The little motors are so limited. It's either speed or torque but not both. Sorry.
01-11-2015, 07:09 PM | #3 |
I think i worded this wrong , Right now it has a stock motor , I also have a second rig with a your 100t in it , so to try it out i put stock tires in that rig and it is very slow. I'm wondering if i can gear down a stock drivetrain rig to get a bit of torque out of it , And if it would run a little cooler.
01-11-2015, 08:54 PM | #4 |
Ah...then yes you can do a 58 or 59 gear on a stock motor. It helps but not a ton. The heat is usually still a factor. But it's worth a try to see if it suits your needs! It will give you more torque but it will slow it down. Good luck!
01-12-2015, 02:13 AM | #5 |
Thanks Dan , I may just order a motor from you and know that the problems fixed.
11-01-2015, 11:58 AM | #6 |
Newbie Join Date: Oct 2015 Location: Bulgaria
Hey guys! It's posted already may be,but I can't find it.What's the stock p/s toooth count? I'm running stock motor/gearing and it's too fast for me. Thanks! |
11-01-2015, 12:24 PM | #7 |
I think the pinion is a 10 and the spur is a 54.
11-01-2015, 01:50 PM | #8 |
Where can I get 58 or 59 tooth spur gear?
11-01-2015, 02:07 PM | #9 |
Hot racing use to sell them.
11-01-2015, 02:17 PM | #10 |
How about this? Losi Pinion & Spur Set [LOSB1752] | Parts - AMain Performance Hobbies - AMain Performance Hobbies The biggest HR spur I found is 56T. Last edited by THX_138; 11-25-2015 at 07:55 PM. |
11-02-2015, 04:04 PM | #11 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
The largest spur gear you can use without modifying is 56t. There is also the option to use a 9 tooth brass pinion which helps. One of the blade micro helicopters uses a 9 pin pinion, the pitch is .3mod and the motor shaft is 1.5mm.
Gearing Question - Similar Threads | ||||
Gearing question | OTHGbronco82 | Losi Mini-Rock Crawler | 6 | 05-08-2014 03:54 PM |
Gearing question | calikrawler | Vaterra Twin Hammers | 2 | 03-11-2013 08:02 PM |
Gearing Question | hibbs | General Crawlers | 3 | 08-28-2011 04:45 PM |
Gearing Question?? | kerrywittig | Axial AX-10 Scorpion | 16 | 07-21-2008 10:47 AM |
Gearing question, | Magic | Chit Chat | 0 | 03-10-2008 02:47 PM |
