02-18-2009, 02:14 PM | #61 | ||
Just need some drive time on it to get used to it. | ||
02-18-2009, 02:27 PM | #62 | |
Rock Crawler Join Date: Nov 2005 Location: Livermore
Do you have links or part # for the motor and pinions? That looks like a great combo and i would like to try it out in my GC2 I am building. | |
02-18-2009, 02:41 PM | #63 |
02-18-2009, 06:14 PM | #64 | |
Here is a link too. http://www.horizonhobby.com/Products...rodID=LOSB0835 | |
02-18-2009, 06:26 PM | #65 | |
RCC Addict Join Date: Feb 2007 Location: LRC
02-18-2009, 06:48 PM | #66 | |
http://www.losi.com/Products/Feature...rodId=LOSB0837 | |
02-18-2009, 06:49 PM | #67 |
02-18-2009, 07:21 PM | #68 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
02-18-2009, 07:43 PM | #69 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
That is what I am running in mine too, everyone thought I was nuts at the last comp! Just waiting for Austin to have some more chassis kits ready.... Paypal waiting! |
02-18-2009, 09:04 PM | #70 |
02-20-2009, 10:45 AM | #71 |
Changed up a couple things after it's first comp, since my battery took a dump and my other packs won't fit on the front axle. Centered the servo Battery fits perfectly between the chassis plates, as well as the esc. I decided to put the rx on the rear linkplate for now, until I get a micro rx for it. Made new steering links I also took the weights out of the rear wheels, as everything isn't in the front of the car now. I will also be adding some lead stick on weight under the servo plate for more front bias. |
02-20-2009, 10:59 AM | #72 |
Rock Stacker Join Date: Dec 2008 Location: 5170 Binder Rd Cashmere
| Steering Link
Dumb question Nathan? Why does everyone use allthread for lengths does anyone use round stock and thread the ends? materials are endless aluminum clear up to ti and everything inbetween? Sorry about such a lame nubie question its really an astetic thing plus not that allthread is spendy but could save a few pennies threading your own again sorry just board I guess |
02-20-2009, 11:17 AM | #73 | |
02-20-2009, 02:50 PM | #74 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
which losi battery is that? I need to find something with a larger mah, because this little 600 only lasts me like 15 minutes max but for some reason last austin like 30
02-20-2009, 02:56 PM | #75 |
| Kevin, Are you running same setup as Nathan ? Centered full size servo,with the battery behind it ?
02-20-2009, 05:57 PM | #76 |
| The Losi pack was the one I originally had on there(600mah), but my LHS ordered in some neat little Zippy 800mah packs. That is the one behind the servo, fits perfectly between the chassis.
02-21-2009, 09:10 AM | #77 |
02-23-2009, 02:02 AM | #78 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
"Holy Shnikes" Nathan, you need to by 2 body's when you build a rig.... 1 body to figure out where it's gonna be finaly placed, and another to replace that swiss cheesed thing of a body you used in the first place! |
02-23-2009, 02:33 AM | #79 |
Like a boss... Join Date: Feb 2008 Location: NorCal
Tanis - one of my buddies just built one of these up and I had a chance to look over the build for a few moments today. I noticed his upper links hit the springs on the stock shocks almost immediately and push the springs off the cups? He was using stock shocks without any limiters but from what I could tell that wouldn't have made a difference. The uppers rubbed almost immediately. You seeing that with yours? or is it a non-issue when running? -Mike |
02-23-2009, 08:22 AM | #80 | |
