01-13-2010, 04:19 AM | #21 |
Rock Stacker Join Date: Jun 2009 Location: Utica
Man you read my mind....I have been searching and asking for pics of this for 2 days now....thank you for the pics!
01-14-2010, 03:07 PM | #22 |
All I did was re-taper the cups and picked up quite a bit of throw! Took all of 2min with a dremel to do it....thanks again!
01-14-2010, 05:34 PM | #23 |
Quarry Creeper Join Date: Apr 2009 Location: Lillington, NC
Tried this about 20 min ago and it worked great. I couldn't find my dremel tool to re taper but i will dig for it and get that done but as of now it hits my stock trimmed up C's on the axle. I do need to grind on the tits some more. I was more nervous about them and didn't take enough off. Cole |
01-14-2010, 05:35 PM | #24 |
Quarry Creeper Join Date: Aug 2007 Location: Winnemucca
I've been beating on mine for a few weeks now with the modded steering, still holding up good A little more fun to drive too since it's manuevers quite a bit better
10-06-2010, 09:02 PM | #25 |
RCC Addict Join Date: Jan 2010 Location: Dallas
Quick way to get this done. Basically trim the cups with a drill press and an oversized bit. Gets you the coned angle.
02-08-2011, 06:04 AM | #26 |
Quarry Creeper Join Date: Oct 2009 Location: northeast ohio
This a awsome mod...Im glad I found this before I went out and bought some CVD's and knuckles....now I can put the money towards the chassis. One question though, I have a HiTec steering servo and It is not turning the wheels to the full capacity. Is there anything I could do to make it function better? |
02-08-2011, 06:28 AM | #27 |
Newbie Join Date: Dec 2005 Location: Robbinsville, NC
You can attach the steering link to a point on the servo arm that is farther away from the center screw to get more throw, but be careful about pushing your servo too hard by hitting the limits of your steering's available travel. If the servo keeps trying to push when the steering linkages have hit the limits of their available travel, you will eventually damage the servo. You can use the dual-rate knob on your radio to dial back how far the servo travels to keep that from happening.
02-08-2011, 10:04 AM | #28 |
hmmm. Well The linkage is on the bottom hole and its the stock controller. Is there a dual rate knob on it.
02-08-2011, 10:44 AM | #29 |
Yeah it's the little knob right behind the steering wheel.
02-15-2011, 06:29 AM | #30 |
I feel dumb now haha, I knew what that knob was, I though you were just explaining a different function
02-15-2011, 06:31 AM | #31 |
Im looking for a steering servo now, will a higher end servo give me more steering throw? Which one do you guys reccomend for the mrc? I have the hitec 645 one now but I want all metal and somthing stronger |
02-15-2011, 02:19 PM | #32 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
Thats a good mod now if you do the zero ackerman mod you will turn much more eficiently check it out. AB Design - "M"VP Chassis |
03-23-2011, 11:54 AM | #33 |
Newbie Join Date: Feb 2011 Location: portland
So I just finished doing this mod and it seems to have helped a bit but I have the same question about servos I still have the stock servo but will a upgrade give me more steering??? And not sure what's going on in the pics about the zero akerman mod any help??? |
03-23-2011, 05:04 PM | #34 | |
Newbie Join Date: Feb 2011 Location: Santee EC SD!!!
here this link has alot of servos data you notice most if not all only have 60 deg. of throw i would say no hope this helps http://www.servodatabase.com/servos/all | |
03-25-2011, 09:21 PM | #35 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
i did this mod n the zero ackerman n it helpd alot seems to not push when turning it it actually turns haha n hav way more throw nice rite up
03-26-2011, 01:17 AM | #36 | |
Quarry Creeper Join Date: Feb 2011 Location: Austin
I believe the speed listed is for 60 degrees. Most servos have more throw than that, but would take longer that the listed speed. Quote:
09-11-2012, 07:40 AM | #37 |
RCC Addict Join Date: Mar 2012 Location: Under a Rock in North Texas
| Re: Modding stock MRC for increased steering throw
Can't believe I just found this. May have to give it a shot, along with the zero ackerman mod. Question, though. Is it possible, or even worth doing the zero ackerman mod on the stock RTR plastic knuckles?
