01-28-2011, 11:51 AM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Help Me Beef Up My MRC!!!!!!
I am a MRC super rookie and am looking to beef up my axles and transmission. I will be running these in a tj scale rig but am looking for some streangth from my drivetrain. What parts are you guys running to beef up these little guy's? Also does the HR metal tranny gears eliminate the need for a tranny locker? |
01-28-2011, 12:01 PM | #2 |
Rock Crawler Join Date: Jun 2009 Location: vacaville
get some lockers for the axle. I dont know about the gears and get some MIP drive shafts and you should be good oh and alum C's and knockles
01-28-2011, 02:55 PM | #3 | |
Quarry Creeper Join Date: Sep 2010 Location: Dewsbury, UK
| Quote:
With the axle diffs upgraqded to metal lockers, the tranny with metal locker, and maybe some metal drive shafts, its pretty tough. To futher improve axle strength, replace the four screws that hold the axle casing together (the four that surround the diff bulge/pumpkin), replace with longer screws and nuts (stops the axle halves spreading under high loads - gears can strip if this happens (We are talking high loads though.) | |
01-28-2011, 08:12 PM | #4 |
Rock Stacker Join Date: Jan 2010 Location: douglasville
It's really not worth the money to get the HR gears for the trans just install all three Losi lockers also the mip drive shafts.
01-28-2011, 11:59 PM | #5 | |
I wanna be Dave Join Date: Sep 2005 Location: USA
| Quote:
Must in my book. HR C-Hub's HR Rear Lock-Outs HR Tranny Gears HR Lockers RCBro's Knuckles Losi CVD's MIP DriveShafts | |
01-29-2011, 05:38 AM | #6 |
I installed the HR trans gears and they lasted a week. for the 25 bux that they cost I can replace the stock trans gears about three times.
01-29-2011, 07:10 AM | #7 |
Pebble Pounder Join Date: Feb 2010 Location: nunya dambidness
drifter something must be wrong with your setup idk but i am apt to believe what run2jeepn says
01-29-2011, 11:09 AM | #8 |
RCC Addict Join Date: May 2009 Location: In the warmth!
I used the HR gears all last season. Just pulled apart the tranny for winter maint. and there is absolutely no wear. Highly recomended. PS, no need for locker with the HR gears. |
03-01-2011, 04:50 PM | #9 | |
Rock Stacker Join Date: May 2006 Location: Ellijay Ga
| Quote:
03-01-2011, 10:18 PM | #10 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
| Wish I had known that part a few weeks ago. Could have saved some money. Oh well now I have extra.
04-15-2011, 09:13 AM | #11 |
Pebble Pounder Join Date: Jan 2009 Location: Lafayette, LA
anyone know what kind of diff lube to use when i install my HR lockers. thanks.
04-15-2011, 02:39 PM | #12 |
Quarry Creeper Join Date: Feb 2011 Location: Austin
04-28-2011, 08:39 PM | #13 |
Pebble Pounder Join Date: Feb 2010 Location: Mpls
I like bearing grease with lithium. About $4 for a tube that will last your entire crawling career. |
04-28-2011, 08:47 PM | #14 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
I recommend NOT going with the "upgraded" straight axles for the rear. I have bent 2 of them so far (they last about 1 comp with luck). I went back to the original dogbone axles in the rear and have had no problems since.
