11-07-2012, 10:33 AM | #1 |
Newbie Join Date: Nov 2012 Location: Indianapolis, IN
| battery position
Need help! I wanna lower the center of gravity of MRC, thinking about to put the battery on servo or between servo and motor. I need some advices. Thanks a lot. |
11-07-2012, 10:40 AM | #2 |
Pebble Pounder Join Date: Oct 2012 Location: Berwick
| Re: battery position
What battery are you using? Stock nimh? If so id mount it on the upper 3 link bar. If you're running a small lipo then either would be fine. Its always gonna be a general personal preference along with what works best on your specific setup. I run on the upper link on one mrc, next to the servo on another, and my favorite place is the rear axle. All I run is 800mah 2s lipo so they're small and don't have allot of weight to them. Plus I have my wheels weighted so running on the back isn't an issue.
11-07-2012, 10:40 AM | #3 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: battery position |
11-07-2012, 10:45 AM | #4 |
Pebble Pounder Join Date: Aug 2012 Location: Australia
When I first bought my Losi MRC RTR I moved the NiMh battery to the top of the servo,I attached it with some velcro. It made a big difference in the centre of gravity. I now have a pro and have put a Lipo battery in between the servo and motor instead of on top of the servo. You are better off with it on the servo performance wise,I just didn`t like the look of it on the servo with the pro. It still performs well with it there,just not as good. |
11-07-2012, 03:46 PM | #5 | |
| Re: battery position Quote: | |
11-07-2012, 05:53 PM | #6 | |
Thanks for your advice. | |
11-07-2012, 05:56 PM | #7 | |
| Re: battery position Quote: Thanks | |
11-07-2012, 06:01 PM | #8 | |
How u put battery between servo and motor? Do you have enough space? I tried to do that, but ends up not enough space. Did you put any mods to make it work? Thanks a lot. | |
11-07-2012, 08:01 PM | #9 |
Rock Crawler Join Date: Sep 2011 Location: Stanford
11-07-2012, 08:29 PM | #10 |
11-08-2012, 02:18 PM | #11 |
Newbie Join Date: Mar 2011 Location: bismarck
Can always Velcro to the inside of body on left side.. keeps it low and helps tt
11-08-2012, 07:59 PM | #12 |
11-08-2012, 08:24 PM | #13 |
11-10-2012, 11:32 AM | #14 |
Quarry Creeper Join Date: Nov 2010 Location: mandan
I made a plate that bolts to servo mount. and my batt sits behind servo and above upperlinks so the weight is on the front axle. I just run 800 2s batteries
11-10-2012, 11:37 AM | #15 |
Tags |
battery, gravity, position |
battery position - Similar Threads | ||||
stock battery mounting position... | jayrat | Axial XR10 | 5 | 07-18-2012 10:55 PM |
Battery Position | Mini | Losi Mini-Rock Crawler | 25 | 08-18-2009 11:47 AM |
battery position | ped453 | Losi Mini-Rock Crawler | 4 | 06-07-2009 04:06 PM |
Question about AX10 battery position | microdot | Newbie General | 8 | 03-04-2009 02:24 PM |
battery position | frsttimer | Newbie General | 14 | 01-18-2008 08:14 PM |
