06-08-2015, 11:27 AM | #41 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Codyboy's MRC that wants to be........ Quote:
Did you check out the closed cell foams in your tires? They are cut from a Goodwill find. I love to repurpose and recycle! | |
06-08-2015, 11:42 AM | #42 | |
RCC Addict Join Date: Jan 2009 Location: Bend
As far as ESC settings, I haven't a clue. I usually just play with the throttle curve over and over till I find what I need. Drag brake and other settings should be similar. Find what works for you. Yes, I did check out the foams. I've never played around with closed cell foams other than in my Slash, but i REALLY like the feel of them. Almost makes me wander if I shouldn't be running some in my scale build as well. I have some foam that feels similar, so maybe I'll steal an idea or two from the set you made me, and make a little bigger set for the larger tires. BTW, a huge thanks again for the tires and foams. It will be a while till I get back to tinkering with the mini, but when I do those will be mounted first. | |
06-08-2015, 12:21 PM | #43 | |
I also make these foams out of the black pipe insulation and contact glue. They work just as good, but don't look as clean. But who cares how they look when they are on the inside of the tire! If you want, give me your tire size and wheel dia and I can do a set for your scaler. | |
06-08-2015, 03:00 PM | #44 |
Newbie Join Date: Jun 2013 Location: Napoli
Hi, With Dravpnir rear upper link and servo mount,I can use the standard rod ends or I must use bigger rod ends? Thanks |
06-08-2015, 05:56 PM | #45 |
| Re: Codyboy's MRC that wants to be........ You could probably figure out a way to use the stock rod ends with shims or inserts. I used Lunsford 4-40 titanium screws for most all the screws on this build. The 3mm traxxas rod ends are a lot stronger and don't look that out of place on a 1/18th scale truck. You could even use 1/8th SS tubing and make your own links. Last edited by CODYBOY; 06-08-2015 at 05:59 PM. |
06-09-2015, 08:46 PM | #46 |
Finally got all the electronics in!!!! All of it is on the Drav Tech's servo mount/ electronics tray. I had to use a shoe horn, but it fit. I had all the electronics in and ready to put the motor in. OOOpppppppsssssss the pinion on the motor shaft doesn't match up with the spur gear!!! The motor has a short shaft, I need a spacer!! So I found a piece of 1/8th" alum scrap and off to the drill press. I used a hole saw to punch out a slug, cleaned it up on the lathe and drilled some holes. Now I'm ready to put the motor in. If you look closely you can see it in the pics. I guess it's called learn as you go. |
06-10-2015, 08:51 AM | #47 |
| Re: Codyboy's MRC that wants to be........ |
06-10-2015, 10:05 AM | #48 |
Rock Crawler Join Date: Feb 2014 Location: ?
Dang. I'd shed a tear if I scratched such a pretty paint job. How does it do climbing vert? I'd think those weights would really plant the front.
06-10-2015, 11:01 AM | #49 |
I was able to hit some lines that I use to be able to do with my comp crawler, keeping mind that my driving skills have a lot left to be desired! But it did surprise me! And for the body, I know the guy that painted it! His cost is pretty cheap for me! |
06-18-2015, 08:05 PM | #50 |
Boy, this thread seems to have become a little quiet. Hopefully it's because everyone's out enjoying the summer! I desided I wanted to add a little wheel weight to my fronts, but I didn't really want to cut up my foams!! So I chucked the wheels up in my lathe slotted two sets so my weights set flush in the wheel. This allowed me to put a little over an oz. in each of them. |
