Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Losi Mini-Rock Crawler
Thread: Shafts for shortened SCX10 shocks
Old 10-16-2016, 10:34 AM   #1
Default Shafts for shortened SCX10 shocks
I'm in the process of shortening some Axial SCX10 shocks and noticed the shafts from my Losi Mini8 are a good fit. The fronts are about 15mm shorter than the stock scx shafts, and the rear Mini8 shafts are about 13mm shorter. Based on how Dravpnir modified his (Dravpnir tries to build something small), I think the fronts will be perfect. I picked up some new plastic SCX10 shocks for $16, and $4x2 for shafts, and few bucks for bladders, these are actually cheaper to make than the Vaterra/Losi aluminum shocks.
Just thought I'd share in case anyone is thinking about making some of these.
TownsendTdi is offline   Reply With Quote
Old 12-15-2016, 09:30 PM   #2
Default Re: Shafts for shortened SCX10 shocks
Turns out the front axial yeti jr shocks are the perfect length.
Shafts for shortened SCX10 shocks - Similar Threads
Shortened WB SCX10 Sand Scorcher CAV-G 1.5 Scale Rigs 4 05-10-2018 07:32 AM
SCX10 II Shortened Wheelbase vincentvega Axial SCX10 II 5 11-10-2016 02:22 PM
