04-21-2018, 06:40 PM | #1 |
Newbie Join Date: Dec 2017 Location: HK
| ECX temper : stiff articulation on one side
Hello I just got an ecx temper and playing it with a couple of days.. I was aware of its torque twist aspect, but i think i have a slightly different problem Even at very low speed, whenever I turn right on flat ground, the crawler lifts its right wheel up to its max articulation (around 3 inches)... I tried to swap the tires, shocks between left/right to see if it could be the strength of the oil shock or some grip issue on one of the tires, but it's the same After further investigation, I noticed something. When I test its suspension articulation by lifting one wheel by 2-3 inch and let go, the left side wheel would always drop back to ground immeidately, but the right side wheel, after articulation would frequently get "stuck" and not drop back to the ground. It seemed to be the same on the rear wheel but on the opposite side (i.e. when i lift the left rear wheel and let go, it won't drop back) I think this "stiffness" of the suspension articulation on the front-right / rear-left is causing the wierd behaviour. Would anyone have advise on how to smoothen the articulation ? (I don't think it's a shock/spring issue because as mentioned i swapped it with the normal side) Thank you |
04-28-2018, 02:24 AM | #2 |
| Re: ECX temper : stiff articulation on one side
Hello Any advise please ? I just took out all the links and put them back just in case but still the same issue THx |
04-28-2018, 12:57 PM | #3 |
Newbie Join Date: Mar 2011 Location: UK
Just guessing really but have tried removing the prop shafts and then do the wheel lifting buy hand thingy ?
ECX temper : stiff articulation on one side - Similar Threads | ||||
ECX Temper | spectre | Losi Mini-Rock Crawler | 30 | 01-03-2017 11:59 PM |
ECX 1/24 Temper | Wavekatcher | Losi Micro-Rock Crawler | 28 | 06-18-2016 08:38 AM |
My new ECX Temper | driftomaniacs | Scale Videos! | 0 | 02-03-2016 08:46 AM |
Ecx Temper | mactools02 | General Crawlers | 2 | 12-28-2015 06:39 AM |
