10-07-2012, 09:01 PM | #1 |
Rock Stacker Join Date: Jul 2012 Location: Owasso
| micro crawler options?
I am going to get a micro crawler so that I can make up some indoor coarses. I plan on going the scaler route I think. Since I am new to all this, I only know of the Losi micro & the redcoats sumo. What are some other option and what are the pros/cos? |
10-08-2012, 01:24 AM | #2 |
Quarry Creeper Join Date: Aug 2011 Location: Sacramento
| Re: micro crawler options?
well the losi micro and and the redcats are the same scale so you can easily fabricate parts to interchange between them. a con would be that redcat sumos have no parts support so if you just want axles you can be VERY lucky and find them here or buy a rtr. the only other rtr micro is the QLOnano wich is 1/32 i believe while the losi micro and the sumo are both 1/24.
10-08-2012, 09:53 AM | #3 |
RCC Addict Join Date: Oct 2011 Location: Crawlerado
Losi. That's the best platform to begin with.
10-08-2012, 10:01 AM | #4 |
I am leaning towards the losi, would also like to see how some of the smaller micros are being built. (Would search but I am on a Kindle and it doesn't like the search bar, kicks me off as soon as I start typing). Where would these threads be found? *should have been "redcat " not "redcoats " , stupid auto correct! |
10-08-2012, 02:08 PM | #5 |
yes if you are new pick up a losi NOT a redcat for losi builds go here RCCrawler Brand Specific Tech - Losi Micro-Rock Crawler at RCCrawler.com and here is my scaler build Mastah Kyler's Chevy Silverado |
10-12-2012, 04:08 PM | #6 | |||
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: micro crawler options? Quote:
Search Results | RCCrawler.com just follow that link and change the search word to what you are looking for as a heads up when searching some of the older build threads Redcat Sumo Micro Crawler = RSMC Losi Micro Rock Crawler = McRC Trail Trekker, well usually trekker but officially listed as MC4x4 and a few have used that. should help some. Good luck! Quote:
Being new to micros shouldn't matter. Neither requires more skill level to build from than the other. Choose based on Budget, axle width,price, and intended goals. if its going to be a slow speed crawler the Losi is your best bet because of the worm gears. if you want more speed or more scale appearing axles get the redcat. Regardless of which you choose Lipo is a good first mod for more power and longer run times. (especially on the sumo) | |||
10-12-2012, 04:33 PM | #7 |
Newbie Join Date: May 2012 Location: Gaylord
look at the Losi Trail trekker if you wanna go to a scale looking rig. For crawling go with the losi micro crawler. which ever you go with, go with a droop set up. because the micros are not heavy enough to make the suspension work. i have a micro crawler and i took the springs off and took them apart and took four spring ball point pens apart and used the spring in the shock bodies.
micro crawler options? - Similar Threads | ||||
Motor options for Micro RC | harlequin | Losi Micro-Rock Crawler | 4 | 01-29-2012 09:27 AM |
BWD Gunmetal Anodized Micro Vertex Options | billet works | Losi Micro-Rock Crawler | 6 | 10-05-2011 10:00 PM |
battery options for micro rc crawlers? | shaybeer | Electronics | 0 | 01-12-2011 07:00 AM |
BWD Black Anodized Micro Vertex Options...Limited Time Only!!! | billet works | Losi Micro-Rock Crawler | 33 | 11-01-2010 05:24 PM |
micro motor options ??? | fordwheeler | Losi Micro-Rock Crawler | 34 | 01-01-2010 09:46 AM |
