Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Government issued Micro
Old 08-10-2012, 04:54 PM   #1
Default Government issued Micro
So I've been all over the RCC Forums for alittle while now with builds like Kyle's Unemployment Wraith (almost finished), A Mini Juice build, a MRC Pro build, and some custom work here and there. I have been wanting to build a Micro Scaler for awhile now and waited for my Wraith to be closer to completion since that's been a big chunk of where my Government paychecks have gone. Now that it is closer I put a thread out for one in the wanted section and A great guy on here named Hittman sold me his. I am so lucky to be so close to where Don has his shop Billet Works Designs so I can get parts and help when needed as he has the parts I need. I got the first set of brass barrel nuts from him along with a set of Wheel wideners. Can't wait to start building. So here is what I got so far.
Micro crawler chassis (from Hittman)
SMC 4.5 Chassis
1/24 Scale Hilux body from Japan (on the way)
HR internal air shocks
HR knuckles
HR C-hubs
HR lockouts
HR main center gear case
Billet Works Designs brass barrel nuts
Billet Works Designs wheel wideners
Billet Works Designs custom wheels (soon to come)
RC4WD Mickey Thompson Baja Claw TTC tires
McMaster Carr 2.0x6mm chassis screws
Fast Eddy bearings
Losi 4x4 driveshafts and micro crawler driveshafts (mod to both coming soon)
Losi all new internals in axles and tranny
I will put in categories when I get more stuff.
bagged86 is offline   Reply With Quote
Old 08-11-2012, 01:23 PM   #2
Default Re: Government issued Micro
looks like you got all the parts for a build
i'd like to see close up photos of those widener parts i still don't get it how it works and been reading here but no photo of how it really works i know it makes it wide but how? what parts are needed? etc
so update us on the build
TwentyF4rth is offline   Reply With Quote
Old 08-11-2012, 02:25 PM   #3
All that is needs is the wideners and barrel nuts. You just take off your wheels and wheel hexes and the slide the wideners over the axle pins just like the wheel hexes. Then put your wheels hexes on after the wideners and then the wheels. The barrel nuts are last and replace the wheel nut which slide through to the axle which takes the distance from when you added the wideners. I'm waiting on some more parts to put it all together.
Old 08-12-2012, 08:30 PM   #4
Ok so not done yet but I'm terrible at dropping what I'm doing and taking pics. Built most of the cage and still gotta cut the body out for the Baja Claws.
Old 08-13-2012, 11:06 AM   #5
Just won a 1/24 Hilux Model on EBay for 34.00 BIN. It says they have one left also.
Old 08-13-2012, 12:49 PM   #6
Guess I'll be following this one, too. Curious to see what those customer wheels are going to look like. Didn't realize BWD was so close to home, either. I think you should definitley try it out with the stock motor and gearing first. Run it for a while that way and then upgrade to the Danally Big Block Kit. Night and day difference! Be sure to upgrade to a 2S lipo, too, when you do that. I ran it with a single cell lipo out of one of my micro helis and it was god awful slow.....slower than stock even. Much better with the 2S in there now! Like a brand new truck!
I'll be buying my wheels & tires shortly. Got some $$$ left from my Mexico trip, so I think that's where I want to put it. Just gotta decide which wheels. I want aluminum beadlocks, but not sure I want the RC4WD ones. Someone needs to make a set of Walker Evans, ATX Slabs, or Monster beadlocks for micros.
Sh0rtBus is offline   Reply With Quote
Old 08-13-2012, 05:54 PM   #7
I have a couple of 2s lipos already that are super tiny from Dual Sky. Yes that is great advise Shortbus to run the sticker first. I finally got my ESC in so I have enough to run it now just need to have alittle time to build. I have been on the ede of my seat waiting for these wheels hopefully this week I'll get them (hint hint Don) lol I hope to show alittle something different as far as my style we shall see. I finally ran the big bad wraith for a shakedown without breaking anything major whoot whoot lol
I'll be at the table tonight finishing the exo cage for the ford Xmod body.
Old 08-13-2012, 06:41 PM   #8
My wraith has issues. I've got more run time out of my and mrc. About to pull the on a set of dark soul beadlocks
Old 08-15-2012, 03:12 AM   #9
Got alittle more done fenders cut out and the front chopped off
Before
After
Old 08-15-2012, 08:10 PM   #10
Hey guys I have a couple of ideas for mounting the model Hilux body but would like yalls tried and true opinions. If you have done a couple voice your ideas please. Also does any company make mounting tabs for the bodies?
Old 08-17-2012, 09:14 PM   #11
Lookin what I've got. Don did a kickass job on these. Match my wraith best for how small they are. Looks like I'll be cutting some more screws.
Old 08-17-2012, 09:34 PM   #12
I joined the Band!
Im lovin the micro machine wheels!!!!
TNCrawler is offline   Reply With Quote
Old 08-17-2012, 09:40 PM   #13
Huh lol there Billet Work Designs and he designed a set of Delrin beadlocks.
Old 08-17-2012, 09:44 PM   #14
Also on the way is a SMC 4.5 Chassis and new tranny gears along with two models Hilux and a Datsun. Went to hobby town for a tap and came out with paint, 9/32 aluminum rod (driveshaft mod), and of course the tap.
Old 08-17-2012, 09:47 PM   #15
I joined the Band!
I just meant they are tiny
Old 08-17-2012, 09:53 PM   #16
Lol yeah and it takes getting used to small bolts for sure
Old 08-17-2012, 09:59 PM   #17
Everything I wanted in a wheel
Old 08-18-2012, 08:08 AM   #18
Not bad man. Not bad at all.
Old 08-18-2012, 03:48 PM   #19
Making some progress today. All dummy screws cut and wheels mounted
Old 08-19-2012, 07:14 AM   #20
Not bad? Hell those look badass! Those rings may just make me keep my vertex's, I want some!
MGCrawler is offline   Reply With Quote
Government issued Micro - Similar Threads
I am Done with the United states government. holycaveman Chit Chat 317 07-02-2012 10:27 AM
Does the government really control gas prices? holycaveman Chit Chat 28 04-13-2012 07:51 AM
wraith at government cove nuggsmoker Videos! 9 01-07-2012 07:33 PM
Steve Wynn's take on the Government JeremyH Chit Chat 0 07-27-2010 06:41 AM
A way to run a government major94 Chit Chat 5 07-21-2010 06:04 AM
