12-14-2014, 09:45 AM | #41 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Re: NEW HSP 1/24 crawler
What setup are you running in that , It looks like it has good wheel speed and torque.
12-14-2014, 10:31 AM | #42 | |
Newbie Join Date: Oct 2013 Location: indiana
| Re: NEW HSP 1/24 crawler Quote:
I looked up my ebay history, I can't remember the size gears exactly its been over a year. The spur gear is the 56t for the micro rally/sct The pinion size I'm not sure of, but its from the 10t-13t metal gear pinion set for the micro rally/sct. It has the aluminum transmission The slipper clutch is super glued onto the spur gear so it can't slip. 7.4v lipo Metal gear servo Driven's no shock torsion bar chassis The motor, axles and esc are the only stock items to be honest.But my favorite mod is the chassis, it really works well for utility work like towing and plowing.I honestly think my Trail Trekker has the balls to launch my yacht, its 29" and 3lbs.It would just look silly doing it. | |
12-14-2014, 10:35 AM | #43 |
Thanks bud , It seems like you got the right combo.
12-14-2014, 04:02 PM | #44 |
| Re: NEW HSP 1/24 crawler My Losi is probably the only rc I have that id trust bringing on a vacation without a single replacement part, its a very reliable truck now.Upgrading these things is more important then the brand or anything like that. But I'm glad you bumped this thread, I needed to knock the dust off the Hsp and start thinking about its future.I recently bought a few 4 channel Tactic Micro Transmitters used, one of them would be perfect for a 6x6 or 8x8 build. Heck the price of the 4 channel Tactic new, along with 2 Hsp's is nearly $100 less then buying just 2 new Losi's. $70 a Hsp x 2 = $140 Plus $35 for a new Tactic Micro tx = $175 Plus $30 for a rx = $205 Two new Losis are $300....$95 of savings covers the transmission, motor, esc, maybe even more.But since I'll be starting off with 4 channels I'll be able to persue crab walking and maybe a utility item like a mount for my plow I can raise. |
12-14-2014, 04:30 PM | #45 |
I'll be watching for a build thread.
01-10-2015, 12:09 AM | #46 |
Pebble Pounder Join Date: Dec 2011 Location: shelby
I bought one of these trucks a while back and got tired of constantly fixing the u joints so i took a piece of fuel tubeing that went from u joint to u joint, trimmed the sides so it fit in the yoke, glued a small plastic rod in each end and drilled it out for a pin. It works great and under a load/ stall it only twists about 1/4 of a rotation (not even noticeable with worm gear drive). It flexes with the suspension and should last forever.
01-10-2015, 07:09 AM | #47 | |
01-10-2015, 07:20 AM | #48 |
I will once my kid brings it back from grandmaws lol. He has abopted it as his own atm.
01-17-2015, 12:26 PM | #49 |
Newbie Join Date: Jun 2004 Location: Panama City
The $100 metal version has a discount right now. I wonder if it is Losi compatible too?
NEW HSP 1/24 crawler - Similar Threads | ||||
hsp 1/8 rock crawler | cooper69 | Newbie General | 16 | 10-15-2014 12:19 AM |
HSP Crawler ? | ClydeBuilt | General Crawlers | 35 | 05-07-2011 04:42 PM |
Hsp Rock Crawler 1:8 | soad95 | Axial AX-10 Scorpion | 3 | 03-05-2009 10:44 PM |
Video HSP crawler | Teubber | Videos! | 0 | 02-24-2009 04:39 AM |
