Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Rc4wd Z-W0229 Stamped Steel 1.0" Stock Beadlock Wheels (Black)
Old 04-11-2016, 08:13 AM   #1
Default Rc4wd Z-W0229 Stamped Steel 1.0" Stock Beadlock Wheels (Black)
They in stock.I ordered set with new rock crushers.
bolo79 is offline   Reply With Quote
Old 04-11-2016, 10:32 AM   #2
Default Re: Rc4wd Z-W0229 Stamped Steel 1.0" Stock Beadlock Wheels (Black)
The most frustrating beadlock to mount to date (well, since the first steel rc4wd beadlock), but they do look nice!
TownsendTdi is offline   Reply With Quote
Old 04-11-2016, 12:27 PM   #3
LOL �� I'm up for a challenge.I hope they heavy.
Old 04-12-2016, 04:46 PM   #4
So will the wheels fit all the existing tires, any thoughts on the new dirt grabbers that came out with the beadlock wheels
hobby machine is offline   Reply With Quote
Old 04-12-2016, 06:12 PM   #5
I believe so.in rc4wd store they suggest tires,all of them ��. Dirt grabbers?I need something with lower profile and much more aggressive Still nice tires just not best for crawling.
Old 09-15-2016, 05:42 PM   #6
Ok, so I got these wheels and the Scrambler tires for my Trail Trekker. Tires are good but the wheel quality is such chit I was laughing at how frustrated I was with the failure of this project. The screws are buttery soft and strip immediately as well as the bead does seal up and tighten the tires. In order to use these wheels I'm just going to have to glue them together. Its funny the tire quality is so much better than the wheel quality. The wheels are total joke.
kennebell50 is offline   Reply With Quote
Old 09-16-2016, 07:16 AM   #7
I just got the same set up yesterday in the mail. My frustration is with the wheel nut. What are you guys using as no tool I have will fit when the wheel is ready to be mounted. I even milled a old rc wrench and it still doesnt work right.
Gambolified is offline   Reply With Quote
Old 09-16-2016, 07:20 AM   #8
The wheel nut and center piece has to go on first, then put the six screws in after you do the wheel nut. My problem is the screws were so soft they stripped out before even half tightened. The setup is a joke and I don't suggest these to anybody. RC4WD should be ashamed of this product. Wish I had spent the extra $20-30 on aluminum beadlocks.
Old 09-16-2016, 11:11 PM   #9
I have them both an luckily kept the wheel nuts from the aluminum set. Backwards they work just fine. I hear what you're saying about them being soft though. What I noticed is that each one is pu together in a specific pattern as not all holes are in the same spot. I'm looking at a way to fix the hub to the rear so that it is three piece, not four.
