Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Bronco Beast........no, this is no Ambush!
Old 11-27-2016, 10:50 AM   #1
Default Bronco Beast........no, this is no Ambush!
This rig has been a blast to build. It just keeps getting better and better. Ive got a few other motors coming in to try out as well. So, here's the current specs on my Bronco Beast.........
Esc- sidewinder micro II
Motor- pulled the 180 motor from a mg958 servo, already has the pinion too
Receiver- futaba
Battery- 3s 180mah or 2s 260mah
Servo- Hitec hs225mg mini
Tires- rc4wd scrambler off road
Chassis- rc4wd gelande
Axles- rc4wd gelande
Brass knuckle weights- sourced on ebay
Tgreer is offline   Reply With Quote
Old 11-27-2016, 12:24 PM   #2
Default Re: Bronco Beast........no, this is no Ambush!
Awesome build
Ballistic17 is offline   Reply With Quote
Old 11-28-2016, 07:25 AM   #3
Great build Thommy! Can't wait to see this bad boy in person.
papabash is offline   Reply With Quote
Old 11-28-2016, 08:51 AM   #4
Whoa! Super rad build Thommy!
Szczerba is offline   Reply With Quote
Old 11-28-2016, 10:25 AM   #5
Wow, what a cool build, looks like it a very aggressive micro crawler!
joe122 is offline   Reply With Quote
Old 11-28-2016, 11:07 AM   #6
I'm curious about how you got that 180 motor to fit. Does it bolt right in, or did you modify it to fit? Also, I'm wondering what shocks your running? Those are not stock obviously. Do they allow for more flex? And one more question, are those the brass wheel weights for the micro crawler, or the trail trekker?
R.Billy Rob is offline   Reply With Quote
Old 11-28-2016, 11:41 AM   #7
Originally Posted by Tgreer View Post
That's a great idea, that rear diff gets hung up on rocks like it's some kind of rock magnet.
TownsendTdi is offline   Reply With Quote
Old 11-28-2016, 11:48 AM   #8
The only thing I did to the transfer case was make the motor hole a touch bigger for the collar of the motor to slide in. The motor even came with a pinion that works and the mounting holes line up perfectly. The shocks are sumo micro crawlers with the RC4WD rod ends. The springs are from some pens I tore apart. The brass weights are designed for the trail trekker, but they bolt right up. Only thing I did was make the center hole on the wheel a touch bigger to allow that barrel nut to slide through.
Old 12-01-2016, 06:57 AM   #9
Went over to my Buddy with RC Scale Worx last night and got a couple of cool 3d items printed for my rig!
Old 12-01-2016, 08:25 PM   #10
Those new items look fantastic! That grill really sets it off, Mike did a great job on it.
Old 12-12-2016, 09:20 PM   #11
Got some fender flairs and wheel wells done. Also made some killer tires for it! I loved the size of the rc4wd scramblers, but liked the more aggressive tread of the rock creepers, so I used 6 creepers and the sidewalls from the scramblers and made some really tall creepers! They are fantastic!
Old 12-13-2016, 04:23 PM   #12
Natedog's Avatar
Very nice micro with aggressive trail setup!
Love the details.
Very nice fitting larger motor.
3d grill really adds to it!
... wheel wells done. Also made some killer tires for it! I loved the size of the rc4wd scramblers, but liked the more aggressive tread of the rock creepers, so I used 6 creepers and the sidewalls from the scramblers and made some really tall creepers!
Any body off pics with wheelwells installed? Tires are perfect and the steel white spokes set them off perfectly!
Old 12-13-2016, 06:44 PM   #13
Mucho better look!
Old 12-23-2016, 06:43 AM   #14
What does it crawl like with the motor ? Does it have enough torque ?
drzjohn is offline   Reply With Quote
Old 12-24-2016, 09:29 PM   #15
Yep, has plenty of torque. I did lose some with the huge tires, but it's 10 times better than stock!
Old 12-30-2016, 01:59 PM   #16
Great car!
Looks like you have improved the steering seriously compared to the stock gelande. How did you manage to get that nice steering?
Sent from my iPad using Tapatalk HD
EyeAmMe is offline   Reply With Quote
Old 01-12-2017, 01:14 AM   #17
With that motor did you have issues with the nut for the upper rear link?
Does yours sound obnoxious now, or is it is just MY old servos motor? Definitely more torque, but its noisy now(for me)
Great build! Hope its still treating you well.
You mentioned trying other motors, any luck?
SurfinStud is offline   Reply With Quote
Old 01-12-2017, 03:12 PM   #18
This motor works brilliant. It is noisier though.
Old 02-16-2017, 12:05 PM   #19
Natedog's Avatar
UPdates? Video? PLease.
Old 04-18-2017, 10:56 AM   #20
Great build, I like the innovation and execution. Excellent job on the tires. What wheels are those and where did you source them?
Thanks crash
crashradius is offline   Reply With Quote
Bronco Beast........no, this is no Ambush! - Similar Threads
Pitbull Rock Beast VS. Growlers Vs. Mad Beast (1.9) Flim Flam Tires and Wheels 31 08-02-2016 03:02 AM
My Ambush v. CGR GTFO!! OG AMBUSH STATUS kikcaffine Axial SCX-10 5 07-24-2009 07:58 PM
Ambush Crawln Coles Paint and Body 28 03-19-2007 12:30 PM
