12-29-2016, 06:45 PM | #1 |
RCC Addict Join Date: Jan 2011 Location: Forest Floor
| 1980 Ford Bronco Rock Crawler
Here is a build I'm currently working on. It's a 1980 Ford Bronco, 1/24th scale, Trekker based. I modified the axles by removing the servo trays. On the rear I made lockouts. For the front I adapted the steering linkage to work longitudinally. I made a custom chassis with a rear mounted steering servo. There is a simple pushrod to connect the two. There is zero bumpsteer. Works great. I also made the usual losi axle mods for better clearance. I made custom low profile brackets for the links and shocks to attach, since I removed the factory upper link and shock mounts. The trans got a 56t spur and a 9t brass pinion and a Danally DDT 90t motor. Love that combination. I cut away at the interior tub and body to get the body low. I have the driver and motor ready to go. The motor is a 351 Windsor. I cut out the doors, and that briefly covers up to now. Last edited by Fungi; 12-29-2016 at 06:49 PM. |
12-29-2016, 06:52 PM | #2 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
| Re: 1980 Ford Bronco Rock Crawler
Looking good. Im loving the body and motor! Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
12-31-2016, 02:40 PM | #3 |
Pebble Pounder Join Date: Mar 2016 Location: Houston
I like those tires and rims, where are they from? Sent from my SM-G930V using Tapatalk |
12-31-2016, 04:02 PM | #4 |
Thanks Jcplante! Basicbilly, The tires are Rok Lox $7 a pair from RC4WD. The rims I made using my 3d printer, but I sold it last year. I still have some left though, so send me an E-MAIL if you are interested in a set. I got the inner tub cut away, and most of the filler pieces installed. I sanded off the bronco emblems and side turn signals on the front quarter panels (rocks knocked them off). I cut away even more on the front wheel wells. Looking forward to making the roll cage. |
12-31-2016, 04:34 PM | #5 |
Quarry Creeper Join Date: Oct 2016 Location: West Michigan
That looks great!
12-31-2016, 10:37 PM | #6 |
You sold your 3d printer?! Im guessing that means you are not selling the micro wraith style chassis anymore? Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
01-01-2017, 02:55 PM | #7 |
No, it doesn't mean I quit selling the chassis. It means I'm using a service to make my parts. Click on the links in my sig for my website, shapeways site, etc. |
01-01-2017, 03:54 PM | #8 |
Ahh ok. I have heard good things about shapeways. Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
01-05-2017, 08:13 PM | #9 |
I did a little sanding and added some putty, cut away a little more from the front of the doorways. Next I hide (cover) the cut outs for the transmission and motor to fit properly. |
01-06-2017, 03:39 PM | #10 |
I got a good start on patching the holes in the floor. I also removed the lower plastic trim pieces, cause you know, the rocks broke them. Just like the Bronco logo all that's left are the holes in the body. |
01-06-2017, 04:39 PM | #11 |
Rock Crawler Join Date: Dec 2013 Location: Nevada City
Looking good Jim! Can't wait to see what you do with paint.
01-06-2017, 04:43 PM | #12 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
So where are battery and esc going?
01-06-2017, 06:50 PM | #13 |
| Re: 1980 Ford Bronco Rock Crawler |
01-16-2017, 04:46 PM | #14 |
Update. I sanded some stuff, filed some stuff, drilled some holes. Added some paint, glued some things. Had some fun. Thanks for watching. |
01-16-2017, 05:15 PM | #15 |
Mad jelly. That looks great
01-17-2017, 04:22 AM | #16 |
Its looking great! I dont see many micro builds with full interiors. Awesome work as usual man! Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk |
01-20-2017, 04:32 PM | #17 |
Thanks for all the comments. Blackout the grill and the complete underside. worked more on the dash and engine compartment. Changed tires and wheels. Thanks for watching! |
02-06-2017, 02:34 PM | #18 |
A little update, Driver dude is glued in. Steering wheel is made from scratch. Painted a lot on the driver dude. Shifters are installed. I may tape it all up and do the exterior, or install the roll cage first. |
02-07-2017, 11:16 PM | #19 |
Newbie Join Date: Feb 2015 Location: Roma
Hi Jim ....amazing work! did your chassis fit in to other mini crawler also or just Losi? because I have seen it's very difficult found one 1/24 Losi crawler for sell. |
02-07-2017, 11:26 PM | #20 |
Rock Stacker Join Date: Jan 2017 Location: Dixie
Awesome man! I dig it Sent from my iPhone using Tapatalk |
1980 Ford Bronco Rock Crawler - Similar Threads | ||||
Jim's 1980 Ford Bronco (evolution of a rock crawler) O.o | Fungi | Losi Micro-Rock Crawler | 8 | 01-30-2015 10:25 AM |
Rock race axial wraith ford bronco | gionata78 | Scale Videos! | 0 | 12-04-2013 01:03 PM |
79 Ford Bronco Micro Crawler | JDoster | Videos! | 4 | 01-14-2012 10:20 AM |
