Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Battery for SCX24
Old 05-17-2019, 06:41 AM   #1
Default Battery for SCX24
Has anyone found the battery dimensions for the SCX24? I can't find the size. I'd like to order some spares so I'll have them when I get this.
Sent from my SM-G955U using Tapatalk
Duramarks is offline   Reply With Quote
Old 05-17-2019, 07:25 AM   #2
Default Re: Battery for SCX24
Its a standard 2s 350mah lipo and on a flat plate with a strap so anything in the 350mah range should fit fine and give you 30-45 min run time
Sent from my LGMP450 using Tapatalk
spoo76 is offline   Reply With Quote
Old 05-17-2019, 10:31 AM   #3
Ok, Ill order a couple. Thanks!
Old 05-17-2019, 10:49 AM   #4
Keep in mind there are different connectors and what's in the pictures may not necessarily be what's in the production version so you might have to be handy soldering and have some different spare connectors on hand
Battery for SCX24 - Similar Threads
Pre-Order Now - New Axial SCX24 Deadbolt 1/24 Scale 4WD RTR RPP Hobby RPP Hobby 0 05-16-2019 12:03 PM
Bomber battery tray wont fit new Lipo battery rock1997 Axial RR10 Bomber 10 08-20-2016 10:36 AM
Axial SCX24 Trail Honcho WAFFLE General Scale Talk 4 01-24-2014 04:42 PM
