Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Scx24 long travel shocks
Old 10-15-2019, 03:37 AM   #1
Default Scx24 long travel shocks
Found my old box of parts from a few exc barrage minis I had 2 years ago.
Just so happens that the shock bodies and pistons are the same threads as the axial scx24.
Instructions:
Take the ends off the stock scx24 shocks.
Remove the spring and little spacer on shick body.
Take the ends off the ecx barrage shock.
Remove spring.
Put top end from scx shock onto ecx shock body.
Cut ecx spring to your preferred size. (This has to happen if you chose to run the stock spring from the scx as it's too short. The shorter you cut the ecx spring, the more droop you'll have.)
Install cut ecx spring with cut end toward the top of the shock.
Install spacer from scx shock with the flat part against the ecx spring.
Install scx spring.
Install scx end.
Profit.
Of course you can substitute the springs for whatever you'd like.
I will mention that the ecx shock bodies and pistons are less smooth than the scx. But for me it will work. You could probably add some grease to smoothen it.
Sent from my SM-N960U using Tapatalk
VN1MVL-24 is offline   Reply With Quote
Old 10-15-2019, 04:07 AM   #2
Default Re: Scx24 long travel shocks
Nice work.
I'd look for a way to raise the upper shock mount for lower center of gravity while maintaining your increased flex range.
klampykixx is offline   Reply With Quote
Old 10-15-2019, 04:13 AM   #3
Originally Posted by klampykixx View Post
Nice work.
Thank you.
I plan on making some tubular shock towers out of brass tube after a while. I've also got a scale hard body going on so it will droop more than the pictures here.
Old 10-15-2019, 04:14 AM   #4
Sounds good to me
Scx24 long travel shocks - Similar Threads
Long travel shocks ToSte Newbie General 1 07-15-2015 01:28 AM
long travel shock's Cork 2.2 Scale Rigs 6 09-21-2014 05:57 PM
Axail Wraith long travel shocks ktmrider Axial Wraith 20 05-13-2014 05:47 AM
Long travel shocks f/r? xLPlushy Axial Wraith 21 05-27-2012 01:33 PM
long travel shocks xiteamxi General Crawlers 21 11-04-2011 01:27 PM
