Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: SCX24 Shock Grease
Old 03-11-2020, 08:18 AM   #1
Default SCX24 Shock Grease
Has anyone found a grease they’d recommend? I tried “white lithium grease” (which I’ve used in RC transmissions before) and it was too thin. I’ve also tried some ultra heavy Traxxas diff fluid (20 million weight), which was way too heavy; almost solid. My next attempt is something like this:
http://www.walmart.com/ip/Super-Tech...z-Tub/16795246
If someone has something that’s readily available at Home Depot or Lowe’s or a part store, I’d like to know about it.
Thanks!
Wisceaux is offline   Reply With Quote
Old 03-13-2020, 06:25 AM   #2
Default Re: SCX24 Shock Grease
i used lucas red an tacky 2 should find it at any wallmart
tdevilman2009 is offline   Reply With Quote
Old 03-13-2020, 08:49 AM   #3
The one I linked above seems to work pretty well. And it’s cheap. Also, it’s a huge tub lol, so now I have a life time supply of grease.
SCX24 Shock Grease - Similar Threads
SCX24 Shock upgrade ??? JLOC Micro Scale Rigs 42 05-06-2020 12:38 PM
SCX24 Shock and Tire Upgrade LRTd5 Videos! 2 02-25-2020 01:27 PM
Steering servo upgrade and shock mod SCX24 waqr Micro Scale Rigs 6 01-10-2020 08:58 AM
Scx24 vertical climbing / reverse shock? Exalted85 Micro Scale Rigs 5 09-19-2019 04:46 PM
Sawback shock grease prem1032 G-Made Crawlers 0 05-28-2014 06:39 AM
