04-10-2020, 01:54 PM | #1 |
Newbie Join Date: Apr 2020 Location: Shady cove
| Scx24 motor upgrade
Anybody know what kind of motor I can put in my account 24 I burn out one and my second one has only had 2 charges and it’s hopping in reverse Sent from my iPhone using Tapatalk |
04-10-2020, 01:59 PM | #2 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
| Re: Scx24 motor upgrade
HobbyPlus CR-24/CR-18 030 motor in 100t for a bolt in motor upgrade. Available on AsiaTees The slightly longer 050 motor from an ECX Barrage/RGT Adventurer/FTX Outback available on AsiaTees and eBay, you will have to drill motor mount holes in the opposite position. (Easy) Generic 050 high torque motors from eBay. Some need motor mount holes drilled. Or one of the best brushed combos is a PN racing 130 motor (Big block upgrade) with a brass pinion. And a motor plate adapter Sent from my Pixel 3 XL using Tapatalk |
04-10-2020, 02:12 PM | #3 |
Welcome to the site! I moved this thread to the micro section where it will get more traffic.
04-10-2020, 02:13 PM | #4 |
| Re: Scx24 motor upgrade |
04-10-2020, 02:14 PM | #5 |
I didn't even notice it was in a different section haha. I'm using the app Sent from my Pixel 3 XL using Tapatalk |
03-01-2021, 08:32 PM | #6 |
Newbie Join Date: May 2011 Location: Krum
I can't seem to find anything on that PN motor. Anybody have a link? Sent from my SM-F916U1 using Tapatalk |
03-01-2021, 09:08 PM | #7 | |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: Scx24 motor upgrade Quote:
While you could get this motor alone cheaper and just drill two holes. This makes it real easy! https://www.ebay.com/itm/Upgrade-Hig...4AAOSw87ZgPUy8 This is not the 130 big block. But I think its very nice none the less. It what I run. | |
03-01-2021, 10:16 PM | #8 |
Yeah I was looking at the Barage motor as an upgrade to stock. Just put on some wheel weights and the motor wasnt doing too hot with the low mode on the controller. Wanting to get the RC4WD steel beadlocks eventually and know I'll need something more powerful. I am new to the whole crawling scene, so learning as I go. Thanks! Sent from my SM-F916U1 using Tapatalk |
03-02-2021, 11:25 AM | #9 |
Newbie Join Date: Dec 2011 Location: Colorado
I have put 050 size 55t by hobby plus into each of my boys SCX24s. Polarity is reverse so you will have to swap the leads or pins in the connector. I soldered on the leads from the factory motors since the CR18 leads are a little short. Part number HBP240118 |
03-09-2021, 09:47 AM | #10 |
| Re: Scx24 motor upgrade Interesting. Does anyone know if this motor is better than the RGT/barrage version?
03-09-2021, 10:16 AM | #11 |
I just got the RGT Barage Motor last night. Getting a buddy to reverse the leads for me. Will post the review once I get it going. Sent from my SM-F916U1 using Tapatalk |
03-09-2021, 11:40 AM | #12 |
Newbie Join Date: May 2014 Location: Akron ,Ohio 44312
I bought some barrage motors and they did not come with a pinion. Does anyone know were I can buy some 0.3 mod with 1.5mm bore pinions and what size (teeth count) do you guys run. Also any info on tools needed to change the pinion and any tips on doing it. Thanks for any info
03-09-2021, 11:57 AM | #13 |
Mine was in a separate bag in the RGT motor bag. Almost missed it and threw everything away. Maybe double check if you still have the packaging? Sent from my SM-F916U1 using Tapatalk |
03-09-2021, 11:59 AM | #14 | |
EDIT: MY BAD. ITS OUT OF STOCK. | |
03-09-2021, 06:59 PM | #15 |
So I got the RGT Barrage motor in. So much better!!! I did lose instant reverse, which kinda sucks, but I'll get used to it. I have the Dynamite on back order, so it will be interesting to see what that one does once it comes in stock. Sent from my SM-F916U1 using Tapatalk Last edited by JayHawk; 03-09-2021 at 07:15 PM. |
03-09-2021, 08:50 PM | #16 |
Thanks for the heads up jayhawk , I never even opened the bag yet so i went and looked and they did come with 12 tooth plastic pinions. Stock is 11 and the RC4WD motor has a 10 tooth. Is the Barrage motor any faster and what is the deal with no instant reverse. Also to be sure ,I need to reverse the wires in the plug onthe Barrage motor. And thanks bigworm for the link. At least I have a part # now. |
03-09-2021, 09:09 PM | #17 |
The RGT had so much more power than stock. I have some minor mods, wheel weights and brass hex hubs, that the stock motor got hung up on in low gear. Not sure about why it doesn't have instant reverse. Thought that that was dictated by ESC. Yes you will have to swap wires for it to work and cut 1 leg off your battery tray for it to fit. Sent from my SM-F916U1 using Tapatalk |
03-10-2021, 12:00 AM | #18 |
Newbie Join Date: Jul 2017 Location: Redding, CA USA
Try re-binding your transmitter to fix reverse issue. If you're switching wires, your end points are probably off now or your failsafe isn't registering correctly.
03-10-2021, 04:46 AM | #19 |
Thanks for this!!! I will try this later and report back on the results! Edit: No dice, did not work. Sent from my SM-F916U1 using Tapatalk Last edited by JayHawk; 03-10-2021 at 05:05 AM. |
03-10-2021, 05:51 AM | #20 | |
Pebble Pounder Join Date: Aug 2020 Location: Ohio
On the stock SCX24 receiver/ESC? I believe that this feature is controlled with the black jumper on the brake pins. Axial Racing - AE-6 ESC/Rx (Forward/Reverse) The AE-6 ESC/Receiver features a jumper for setting one of two brake options (brakes, or instant reverse), two LED light ports, an auxiliary port (channel 3), a channel 2 port, and a steering servo port. | |
Scx24 motor upgrade - Similar Threads | ||||
SCX24 steering upgrade | Alexg89 | Micro Scale Rigs | 24 | 08-10-2020 05:30 AM |
SCX24 Shock upgrade ??? | JLOC | Micro Scale Rigs | 42 | 05-06-2020 12:38 PM |
SCX24 ESC Upgrade/Replacement | punkindrublik | Micro Scale Rigs | 22 | 04-09-2020 10:21 PM |
Help me upgrade SCX24 servo | Veteran | Micro Scale Rigs | 22 | 04-08-2020 05:44 AM |
SCX24 Shock and Tire Upgrade | LRTd5 | Videos! | 2 | 02-25-2020 01:27 PM |
