04-25-2020, 07:07 PM | #1 |
Rock Stacker Join Date: Apr 2020 Location: US
| Scx24 Front Overdrive Options?
Has anyone looked into some sort of overdrive options for the scx24? I know it's a micro crawler, but was wondering if there had been any gearing options for the front diff, or even if there was a way to do it with different size tires on front and rear. Any help would be appreciated. Sent from my Z982 using Tapatalk |
04-27-2020, 12:15 PM | #2 |
| Re: Scx24 Front Overdrive Options?
Different sized tires will work although look kinda odd and don't want more than about 10-15% overdrive imo/ime. Would be nice if OD/UD gears were available, but I don't know of any at them moment, maybe somebody else does? |
04-27-2020, 02:15 PM | #3 | |
| Re: Scx24 Front Overdrive Options? Quote:
Sent from my Z982 using Tapatalk | |
04-27-2020, 02:52 PM | #4 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
Interesting question. I wonder if something this small would really benefit from that though? Seems to me that bigger tires, more torque and wheel speed gets almost everything you throw at it done as it is. OP, your posts seem to reflect that you want to mod this thing. I would get a new motor for easy and great bang for the buck results. https://www.ebay.com/itm/Upgrade-you...YAAOSwN8JepKXk https://www.trackshobbies.com/motor-...d-barrage.html IF you want a wider stance, this is a great option. They will space your wheels out and they are beadlocks. You get free crappy, but cool looking monster truck tires with them too. Most use bigger RC4WD tires on these rims (for those who have them). https://usa.banggood.com/HBX-2098B-1...r_warehouse=CN New motor and wider stance really help this thing. Heres how those wheels will look if interested. Bigworm’s SCX24 Build Last edited by BIGW0RM; 04-27-2020 at 03:02 PM. |
04-27-2020, 05:32 PM | #5 |
Rock Crawler Join Date: Dec 2013 Location: Nevada City
Have you looked at Losi micro crawler/ trail trekker axles? I’m not sure if the gear ratios are different, but they are both worm gears. I believe I read somewhere the losi axles are 12:1. Not sure what the axial axles are.
04-28-2020, 06:08 PM | #6 | |
04-28-2020, 11:03 PM | #7 | |
Rock Crawler Join Date: Apr 2012 Location: NewHampshire
I believe the losi axle is geared lower then the scx24. Just keep in mind too the losi axle is much shorter in length. Sent from my iPhone using Tapatalk | |
04-29-2020, 01:50 AM | #8 | |
04-29-2020, 10:32 AM | #9 |
It would be cool if we could change the top gear in the worm assembly. https://www.horizonhobby.com/worm-ge...er-p-ecx202016 |
04-29-2020, 04:49 PM | #10 | |
Scx24 Front Overdrive Options? - Similar Threads | ||||
Wheel and tire options for the SCX24 | chino | Micro Scale Rigs | 21 | 07-05-2021 09:56 PM |
TRX4 Overdrive vs Underdrive Gearing Options | Still Bill | Traxxas TRX-4 | 11 | 09-15-2019 10:05 PM |
Options for vertical front shocks? Options for rear setup? | Brake Weight | Vaterra Twin Hammers | 51 | 12-11-2017 07:52 AM |
Need overdrive for front differential. | DougL | Axial SCX10 II | 19 | 10-19-2017 02:09 PM |
