Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Bigworm’s SCX24 Build
Old 07-04-2019, 08:21 AM   #21
Default Re: Bigworm’s SCX24 Build
Originally Posted by BIGW0RM View Post
Got my carisma oil shocks on. I used the stock springs with the stick spring lower. I used the Carisma mounts up top with longer bolts going into the battery tray mount.
I could not use the carisma ball end mounts on the bottom because I have 4WS and they limit the turning radius by hitting the c hub.
Sent from your iPhone.
Part # Please
Fishmaxx is offline   Reply With Quote
Old 07-04-2019, 10:25 AM   #22
Originally Posted by Fishmaxx View Post
Part # Please
This is where I found them https://carisma-shop.com/en/product_detail.php?id=1463
HumboldtEF is offline   Reply With Quote
Old 07-04-2019, 11:33 AM   #23
They feel no different than stock since I’m using the stock springs. I just have way more articulation. The rear axle almost goes full vertical. I must have 65mm+ of articulation.
It sags in the rear a little to much and I can’t put anymore preload on the shocks.
Messing with rgt adventure shocks springs now.
To be continued...
BIGW0RM is offline   Reply With Quote
Old 07-04-2019, 03:41 PM   #24
They can also be ordered from here https://www.hobbyrecreationproducts....ctions/carisma if you need customer support (tel:800-860-3709) https://www.hobbyrecreationproducts....lled-shock-set
Budman is offline   Reply With Quote
Old 07-04-2019, 08:00 PM   #25
So back to the Losi micro shocks. Do they fit on the scx24 ball studs or do I need to get the Losi ball studs
I do remember something about 5/32 tubing?
Have you tried the Losi shocks on the front yet?
dirtman71 is offline   Reply With Quote
Old 07-05-2019, 08:20 AM   #26
Losi shocks snap on just fine.
And the tubing I used from one shock mount to the other I’ll recheck the size. I bought three different sized rods and I think it might be the 5/32.
Old 07-05-2019, 12:53 PM   #27
Default Bigworm’s SCX24 Build
Carisma oil shocks are bad ass! I used some rubber o rings that you typically use to shield wire going through a wall. And they hold onto the stock ball ends just fine. I had some RGT springs which look identical to the carismas. I cut those down a few rings. And this is end result.
Check out that flex!
Old 07-17-2019, 03:31 AM   #28
Wow, do you have the part number for those shocks?
Sent from my SM-G955U using Tapatalk
Duramarks is offline   Reply With Quote
Old 07-17-2019, 04:27 AM   #29
MSA-1E ITEM NO.16087 Bought mine here: https://www.hobbyrecreationproducts....lled-shock-set
US distributer contact@hobbyrecreationproducts.com
800-860-3709
Old 07-17-2019, 06:10 AM   #30
Thankyou
Old 07-23-2019, 10:51 AM   #31
i just got those shocks for my Carisma Coyote Pup... now I"m thinking they belong on my SCX24... so you just used a grommet to fix the overly large openings. what weight oil are you running?
MrSquiggles is offline   Reply With Quote
Old 07-23-2019, 11:06 AM   #32
I used 35w
Deezul is offline   Reply With Quote
Old 07-23-2019, 11:44 AM   #33
i'll give it a try, thanks!
Old 07-23-2019, 04:13 PM   #34
Correct. I found mine at my local hardware store. Im sure any rubber tube would work. Mine are tight enough to not come off at all. But much easier to remove than plastic on metal ball caps if that makes sense. I left what little oil was in mine alone. I didnt add any yet.
Old 07-23-2019, 04:18 PM   #35
I also have mine installed to the hole your battery tray connect though. And I have cut springs to make it sit where I wanted. Stock height spring is too tall.
RGT springs are exactly the same size and I used those to save my carisma springs. But they look and feel identical.
Old 07-23-2019, 05:33 PM   #36
Just got a little package in the mail from HCP. I didn't realize these little things were kits, I love it! Time to build some tiny shocks...
punkindrublik is offline   Reply With Quote
Old 07-23-2019, 09:48 PM   #37
BIGWORM,where did you find the grommets, I looked at every hardware store I could find.
Old 07-23-2019, 09:55 PM   #38
What are HCP shocks!
Old 07-24-2019, 12:10 AM   #39
Carisma, lol. HCP (HobbyCreationProducts.com) is just where ya get em
Old 07-24-2019, 12:39 AM   #40
I don’t want to seem like a smart ass, it’s hobby Recreation products. sorry, I had a lot of fun keeping track of the bottom shock body cartridge o- rings, I think they could be bought separately they have a part number though
Bigworm’s SCX24 Build - Similar Threads
Scx24 truggy build... lilws6 Micro Scale Rigs 21 08-13-2019 12:28 PM
