04-16-2021, 10:30 AM | #1 |
Newbie Join Date: Mar 2021 Location: Beaverton
| SCX24 Upgrade Parts and my epiphany
I have been struggling trying to get a wobble out of my front end and I think I have been making things worse as I am trying to make it better! I wanted to check and see what others are doing/thinking: I have the Emax ES08MAII installed on a Hot Racing servo mount. I also have the Hot Racing steering linkage. I love these components and they are awesome upgrades! With the weird wobble I have been seeing, I decided to replace the drive axles and went with the Hot Racing +4 mm and added the axle weights. Again, this is all great stuff that I really like! What I just noticed though is that since there is now a situation where the knuckles are spaced further out, additional stress is being put on the normal length steering linkage (my epiphany!!!!) yeah, I’m a little slow on the uptake....). So, I am wondering what you all are doing. Anybody else in this situation? What am I missing? Thoughts? Sent from my iPhone using Tapatalk |
04-16-2021, 03:49 PM | #2 | |
Quarry Creeper Join Date: Jul 2020 Location: US
| Re: SCX24 Upgrade Parts and my epiphany Quote:
The other half says well you can trim it out and get it to drive straight so roll with it lol Read-Up! Mod-On! Crawl EXCESSIVELY! | |
04-16-2021, 06:26 PM | #3 |
Man, my Deadbolt is a mess with all my mods! I might have to pull it back down to stock and see if I can add things back slowly to try and figure out where the problem really is Is this gap normal for folks or is it a symptom of my mess too? I have gaps on front and rear, right and left sides, but they vary in the gap. Stock axle housing and stock covers. Only thing different is the HR Emax Servo Mount. Sent from my iPhone using Tapatalk |
04-16-2021, 06:30 PM | #4 | |
[mention]23drummerboy [/mention] I was thinking it was a special mess on just my Deadbolt, but after reading you are seeing it too, I double checked my wife’s C10 and sure enough, same thing! Hers is not quite as bad, but definitely a little “toed up” for sure... Sent from my iPhone using Tapatalk | |
04-16-2021, 08:16 PM | #5 | |
Start by screwing the four corners in a similar pattern to when you remove and install lug nuts on a real car kind of like a star...(Top left, Bottom Right, BOTTOM left, top right) only thread em till they TOUCH the cover, then run the screws in the middle down till they move the cover evenly over said-"ridge", then repeat pattern until all are "snug", whilst the cover is flush to the axle housing. Alternatively, u could just tighten the center two screws evenly till the cover centers and snaps-down. Read-Up! Mod-On! Crawl EXCESSIVELY! | |
04-16-2021, 08:17 PM | #6 | |
04-16-2021, 08:20 PM | #7 | |
04-21-2021, 09:52 PM | #8 |
So I ended up swapping out my axle housing got as n inexpensive set from eBay. Started reassembly and realized that I had a bent rear drive axle... so I swapped back from the Hot Racing +4’s to stock, and guess what. Yep, bent drive axle! I looked closer at the stock axle housing and it is bent a bit too. Here goes my theory: somehow I managed to mess up the diff cover mounting (blaming myself but not full convinced) which put pressure on the axle housing. The bend in the axle housing put the internal bearings out of alignment. As I moved to bigger tires and more weight, that pressure and jacked up alignment caused the bend in the drive axles which results in the wobble. So it is that, or my kid dropped it or stepped on it or something.... Regardless, I have a new set of Hot Racing +4’s on order and am going to start fresh in the new aluminum axle housings. I am hoping that the stiff housings and new, straight drive axles will fix my problem!!!! ... oh, and now I have to replace worm gear o-rings since I found one of those shredded in the front worm gear ... sigh .... Sent from my iPhone using Tapatalk |
04-22-2021, 09:18 PM | #9 | |
I dont believe everything i hear online (you know what I meant) But i do know i crammed 1-3 o rings in my diff when i added overdrive to front axle on my Betty, and that damn truck hasnt been quiet SINCE! Lol sounds like wheeling...a, ghetto-a** ....Tesla. bahaha Read-Up! Mod-On! Crawl EXCESSIVELY! | |
04-22-2021, 09:22 PM | #10 | |
She likes the garage and flower bed out front, or to be hauled around via TRX 4Sport. (Built indoor crawler section for trucks of similar scale Read-Up! Mod-On! Crawl EXCESSIVELY! | |
04-22-2021, 11:45 PM | #11 | |
When you were putting o-rings in, what size were you using and where did you get them from? I tried without and that front worm gear “ticks” against the bearing - of the bearing itself is mov - and driving me crazy!!! I bought 3 different sized Axial o-rings and they were all the wrong size! The closest I got was a 2.5x1.5mm (P/N: AXA1179) but it was too thick and introducing a lot of extra stress just turning the wheels. I think I need a 2.5x1mm, but I’m gonna pull stuff apart again and measure tomorrow. Any tips on finding a replacement would be much appreciated! Sent from my iPhone using Tapatalk | |
04-23-2021, 03:58 PM | #12 | |
Did you see the shims in the axle? A lot of people miss them because they stick right up against the inside bearing race of the bearings that they are spacing from if that makes sense? In fact I've grown accustomed to rubbing the bearing between my fingers kind of like rolling a joint just to make sure that I'm not missing a spacer that it's camouflaged real well and stuck with grease. Maybe try running two o-rings on the side that's making the tick? If you can figure it out to me it sounds like you have a burr on a bearing race or on the ring gear or whatever is butting up next to the tick lol. I would put shims if you haven't or if you've lost them where the diagram shows which would be on the little worm gear either end before the bearing to act as a spacer so the bearing doesn't chew up the worm. . . . Then maybe try putting two o-rings that when stretched not qqquuuiiiite to their max, match the diameter of the inner bearing races?? You don't even need axial low rings if you can go to harbor freight or whatever tool or hardware store or Fastenal that you can find, just ask if they carry little tiny o-rings I've had great look at Ace hardware or similar places.. not for these o-rings but for itty-bitty e-clips, and other oddities Read-Up! Mod-On! Crawl EXCESSIVELY! | |
04-23-2021, 04:01 PM | #13 | |
06-11-2021, 09:13 PM | #14 |
Newbie Join Date: May 2021 Location: idaho falls
I have also come across this bent drive stub issue front and rear. one of the front dogbones is actually bent! i havent looked at the axle housing itself to see if maybe it too is bent. Id like to find some replacement dogbones. Anyway i have not installed the +4mm drive stubs yet so i cant comment if it causes the "toe in" issue, but i will say the brass knuckles i put on do cause the "toe in". the bearing kit from fast eddy is a must, the stock bearings fall apart in a short amount of time. |
SCX24 Upgrade Parts and my epiphany - Similar Threads | ||||
SCX24 Servo upgrade | JMHZ2401 | Micro Scale Rigs | 4 | 12-19-2020 10:27 AM |
SCX24 steering upgrade | Alexg89 | Micro Scale Rigs | 24 | 08-10-2020 05:30 AM |
scx24 motor upgrade | JMHZ2401 | Micro Scale Rigs | 3 | 05-18-2020 05:11 PM |
SCX24 Shock upgrade ??? | JLOC | Micro Scale Rigs | 42 | 05-06-2020 12:38 PM |
Scx24 shock upgrade? | Jppr26 | Micro Scale Rigs | 5 | 05-04-2020 06:18 AM |
