06-18-2022, 04:39 AM | #1 |
Pebble Pounder Join Date: Nov 2021 Location: Finland
| Micro komodo install help
Hello, received the micro komodo yesterday. Started to install it today. When I mount the motor, and then try to turn it from the universal joint, I have to apply a bit too much power in order to get it spinning. The spur gear is the original plastic one. Turning the motor: it spins fine, no power is needed. Installing the brushed motors was always a straight forward job, no worries. This don’t seem to be Last edited by 2471:24; 06-22-2022 at 12:09 AM. |
06-20-2022, 12:23 AM | #2 |
| Re: Micro komodo install help
Well, it’s a bit of a tight fit, have battery up front on the rails sideways, tegu between the rails behind the motor and proline powerwagon body. There was a bit too much space between the spur and pinion, so had to do it again. Seems working fine, but had no time driving it yesterday. Gonna drive it today.
06-22-2022, 12:13 AM | #3 |
Wow, the new motor is awesome! Yeah, I’ve watched videos but it’s different to crawl it yourself. I can only recommend it.
Micro komodo install help - Similar Threads | ||||
Furitek Stinger Micro Komodo | fastgixxerlv | Videos! | 0 | 04-17-2022 10:03 PM |
Komodo at a very windy Ashover Rock with the Komodo | Paul Roach | Scale Videos! | 1 | 05-06-2019 04:16 PM |
Need Help with Komodo | Scionizer07 | G-Made Crawlers | 4 | 04-13-2016 09:48 PM |
Komodo came in! | GravelDuster | G-Made Sawback | 14 | 11-20-2015 04:35 AM |
