Go Back   RCCrawler Forums > Scale Rigs General Tech > Micro Scale Rigs
Thread: Scx24 Lj build
Old 09-30-2022, 04:11 PM   #1
Default Scx24 Lj build
What's up my fellow scaler nerds!
Longtime no crawl!
2017 was my last login...
It's been awhile.
Just picked up a scx24 deadbolt..
Gonna be using a Lilguy ripper chassis and tires.
ROLANDROCKSHOP is offline   Reply With Quote
Old 09-30-2022, 04:28 PM   #2
Default Re: Scx24 Lj build
You've seen 1...you've seen them all..haha
Build list..
Lgrp ripper chassis
Lgrp gripper tires
Beadlocks AR "outlaw10hole" style
Alum shocks
Metal gear transmission
Metal driveline
Brass knuckles
Reefs servo
Brushless esc and motor setup..
A handful of lipos
Hunting for a Rx TX as well..
Sold off everything Rc of mine.
What's the latest and functional radio setup?
It's gotta handle scalers and comp rigs..so at least a 4ch..
Now I gotta rebuild my inventory..smh
Sent from my SM-A505U using Tapatalk
Old 10-07-2022, 02:34 PM   #3
Mail has delivered!
Parts incoming!
Old 10-07-2022, 04:08 PM   #4
Upper and lower links
Servo mount
Old 10-09-2022, 05:25 AM   #5
Wheels and tires..
What a size difference
Powerhobby mudboss tires
10x the grip
Compound is much more tackyEr than the stock tires.
Definitely needs brass hexs and metal drivelines...maybe just a scooch wider.
I have a feeling things are gonna start showing weak spots with the added beef...lol
Old 10-09-2022, 05:29 AM   #6
Shocks..
39mm alum
Limited the fronts so they don't drop as far.
Left the rears in full cycle.
Gonna look around for some shock towers with multiple mounting points.
Alum axle housings are enroute.
Old 10-10-2022, 09:22 AM   #7
Originally Posted by ROLANDROCKSHOP View Post
Wheels and tires..
My stock motor was running hot after those upgrades. I got the tegu, and suddenly it wasn’t hot anymore. Then it quit, but it lasted quite long. Now running micro komodo. Keep us posted
2471:24 is offline   Reply With Quote
Old 10-15-2022, 12:14 PM   #8
Metal axles...
Need to get cvds and spare gears and shafts..
The brass ring gear probably won't last long with the added heft..
Old 10-17-2022, 09:10 AM   #9
I like the colour coordination between shocks and body Looking forward to seeing more!
ChilliBreath is offline   Reply With Quote
Old 10-17-2022, 09:19 AM   #10
Thanks...
I'm searching for a 24th yota model body
While I save for the Lj chassis and extras.
Old 11-03-2022, 10:16 AM   #11
Nice build! And I just got one myself and find it hard not to constantly buy parts for my Deadbolt
dmcmahan60 is offline   Reply With Quote
Old 11-03-2022, 03:15 PM   #12
Definitely need to get me one of these 1/24 rigs.
Sweetride95 is offline   Reply With Quote
Old 11-04-2022, 07:08 AM   #13
Shocks..
39mm alum
Very nice build, I've been tinkering with mine lately...It's way more capable than I was expecting. Are those oil filled shocks? If so, what brand? I've got the Betty and it crawls well, but the stock pogo sticks have got to go.
OSRC is offline   Reply With Quote
Old 11-04-2022, 08:46 AM   #14
Thanks.
No,these aren't oil filled.
However I did put a drop or 2 inside for lubrication.
The shaft is just a screw with a plastic sleeve over it...so no valve.
Hotracing has an oilfilled shock.
Old 11-04-2022, 01:21 PM   #15
Injora has oilfilled shocks also.
Old 11-04-2022, 01:25 PM   #16
Thank you both!
Old 11-07-2022, 10:09 AM   #17
FYI if you order from INJORA it will take over 2 weeks to get your parts. You can get them from Amazon and get it in less than a week. Or AMain hobbies is a good one also
Scx24 Lj build - Similar Threads
Scx24 build advice Alaskan Micro Scale Rigs 3 02-23-2022 05:04 PM
SCX24 KOH Build motiracer38 Micro Scale Rigs 19 03-16-2021 10:49 PM
VN1MVL Scx24 Build VN1MVL-24 Micro Scale Rigs 36 11-14-2019 07:21 PM
Scx24 truggy build... lilws6 Micro Scale Rigs 21 08-13-2019 01:28 PM
SCX24 Toyota build ajdone Micro Scale Rigs 2 07-13-2019 11:18 PM
