Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: 6x6 Ford Aeromax Log Truck
Old 03-19-2013, 09:18 PM   #1
Default 6x6 Ford Aeromax Log Truck
Always wanted a 6x6 but didnt want to pay for a beast or a worminator so I started with 2 highlift frames, set my length cut and reassembled the two halves. Its running a highlift 3 speed tranny with 3 highlift axles leafsprung with a HR front shaft rc4wd super long punisher shaft and a modified globeliner driveshaft with ballcups on the rear. I also modified the primary axle to accept a double pinion. Electronics are dual AS2 servo's Integy 45t motor Novak Rooster ESC, Spektrum sr300 rx and venom 4600 6 cell. I had my old Areomax semi cab laying around and put it to good use along with the fuel tanks and running boards. To top it off and relieve some stress from my Globeliner, I took my homebrew log bunk and bolted it on to the remaining frame. I will be using 6 Maxxis trepadors and updating this as it progresses. Heres where im at now:
TheManCave is offline   Reply With Quote
Old 03-19-2013, 09:22 PM   #2
Default Re: 6x6 Ford Aeromax Log Truck
Oh lookin sweet. I love the 6x6s
Cypher is offline   Reply With Quote
Old 03-19-2013, 09:27 PM   #3
a long haul loggers truck-
stack 'em high!!!
FATBOYrs10 is offline   Reply With Quote
Old 03-19-2013, 09:31 PM   #4
Hopefully she turns out to be a stout little pulling machine. Still need to work out some steering issues but you never have a finished rig
Old 03-19-2013, 09:35 PM   #5
stack 'em high!!!
You have no idea how long I was sitting there debating on hacking the sleeper off on it. Now im debating throwing a set of custom stacks behind the side fairings or possibly a headache rack
Old 03-19-2013, 09:42 PM   #6
i gotta get me a semi! you let me know if you decide to get rid of the chassis you took that ford off of.
Old 03-19-2013, 09:53 PM   #7
I was planning on parting it out after taking a lot of the parts to retrofit onto the 6x6. Told you they were addicting lol
Old 03-19-2013, 09:56 PM   #8
i just need it in roller form, chassis, axles, and a set of wheels and tires
Old 03-19-2013, 09:59 PM   #9
Its got all that just need to throw a cross member in the front so the leafs are there and you're good to go
Old 03-19-2013, 10:05 PM   #10
cool, well we'll have to see if we can work out a deal maybe when i come to pick up the other tires/wheels we talked about.
Old 03-19-2013, 10:21 PM   #11
Oppan Gangnam Style
chino63's Avatar
Nice start, I like the Aero 6x6 idea, it's different than the norm.
One thing I'd recommend upgrading is that poor little dogbone between the rear axles, it won't last long if you drive like I do.
chino63 is offline   Reply With Quote
Old 03-20-2013, 01:15 AM   #12
Thanks, Ive never seen one so I figured Id be the odd one to try it. That dog bone believe it or not is as strong as the punisher shaft I milled down both ends and filled completely in with a mig welder and ground it back into a shaft rather than a blob. The only issue I ran into is steering. I had to hijack the stock steering link off a semi along with the servo mounts and left turns are almost impossible. I also had to re route the shift linkage to where it runs diagonal opposed to a straight line they way it is stock.
Old 03-29-2013, 09:34 PM   #13
Been a while since I've updated this. Got a few pics from its virgin run, what better way than in mud!
Old 04-07-2013, 06:58 PM   #14
That is a bitchen rig, any more action shots? Needs a stihl saw somewhere
Bronco Bobby is offline   Reply With Quote
Old 04-07-2013, 07:17 PM   #15
man that thing looks sweet great build i dont see buying the rc4wd beast either i think your like me and rather build it yourself
fordsuperduty is offline   Reply With Quote
Old 04-07-2013, 10:37 PM   #16
Why pay 800 for just a rtr frame when you'll end up having over a grand in it when you;re done vs making your own for less than the beast
Old 04-07-2013, 10:38 PM   #17
Looks cool man, especially in the mud
King James is offline   Reply With Quote
Old 04-09-2013, 12:42 AM   #18
Well said.
Bulldog is offline   Reply With Quote
6x6 Ford Aeromax Log Truck - Similar Threads
Truck and Truck Trial / Competition RC /KAMAZ STAR FORD URAL ZIŁ PRAGA MAN KRAZ Rasalo Scale Videos! 3 09-17-2012 07:28 AM
My tamiya aeromax build. tri axle Non Crawler RC's 16 04-10-2012 05:03 PM
6x6 Truck Pete Attryde Multi Axle Rigs 44 12-04-2011 01:13 PM
aeromax pikes peak race truck #148 SEMIJOE Non Crawler RC's 14 01-31-2011 04:38 PM
