![]() | #61 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Great job on that engine. Those injector lines look perfect.
![]() | #62 |
Quarry Creeper Join Date: Jun 2013 Location: Portugal
| ![]() Thanks! While the fake engine and the rest of the parts are getting done outside the car, one more important thing has to be done: make it run properly! The cab has new mounting points(4 screws inside the inner fenders) and attached the bed on the chassis. ![]() ![]() ![]() The bed tips to change batteries, that sit above the middle axle,between the frame rails ![]() And off to the trail!! ![]() |
![]() | #63 |
Rock Stacker Join Date: Jan 2014 Location: online
You did a great job on making this build, copying the detail of the real unimog frame, how the springs attach is great and axle portals too.... The only thing id change is a little bit bigger tires for 1/10th scale look like 2.2's rc4wd micholin tires, the stock unimog tires is 42-46" |
![]() | #64 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
Awesome build brother! keep up the great work!
![]() | #65 |
A little more work on the engine ![]() ![]() Mounted it and the air filter. Needs a couple more parts to fill this bay ![]() ![]() |
![]() | #66 |
While the bay is slowly being completed, did something else: ![]() ![]() ![]() This printed wheel is a copy of the Gmade SR02 already in the truck but thin as possible to fit under the bed as the real one ![]() ![]() ![]() Just needs a mount welded on the chassis |
![]() | #67 |
mudguards: ![]() ![]() ![]() |
![]() | #68 |
RCC Addict ![]() Join Date: Feb 2008 Location: Tekin, ID
Love it, very nice work!
![]() | #69 |
![]() | #70 |
Already had a fuel tank, done years ago and like I feel my skills improved, re-did it ![]() ![]() ![]() ![]() ![]() ![]() Not in the final position (hot glued in place). Have to come up with some kind of support |
![]() | #71 |
Hi guys! I'm on "vacaciones" and can't work on trucks but I've got a 3d printer so can stockpile on parts to apply later I'm fairly new to printing and 3d modeling so have to start with simple stuff,like a license plate: ![]() ![]() quick paint: ![]() A battery is also useful to fill the engine bay. This one it's not my design ![]() |
![]() | #72 |
Did more 2 parts to fill the engine bay: This coolant reservoir: ![]() ![]() And upgraded my old radiator: ![]() ![]() ![]() ![]() After adding everything to the bay, will hide the blinker's wires.... |
![]() | #73 |
took this guy out: ![]() ![]() ![]() Truck runs good. Slow,heavy and without a winch makes think twice in every line. |
![]() | #74 |
Rock Crawler ![]() Join Date: Dec 2012 Location: Utah
Very nice work my friend! Turned out perfectly.
![]() | #75 |
![]() | #76 |
A couple of photos from the last trail run ![]() ![]() ![]() Last edited by cooper_xl; 05-15-2022 at 10:00 AM. |
![]() | #77 |
Hi! Long time without updates So, the truck spends too much time on the shelf. Took it to the trails 2 times in one year :( But, even like that, the truck needs updates,one being a slightly larger fuel tank and the other, adding a rear canvas to the bed, because it was one of my initial requirements,even before the start of the project The idea is to look like this: ![]() My current bed is fine but i've scrapped the idea of the canvas before because there's no way I can put functional hooks on the thin aluminum that's on the bedsides so I'll make a brand new bed for this purpose This time, I'll print the bedsides because of my current personal situation, and doing the floor and struture as before,with wood and PVC sheet 2 prints, 1 side: ![]() How the corners would look like ![]() Giving some wooden texture to the PVC ![]() Small nails to mimic round head bolts securing the planks ![]() Black for panel gaps ![]() Painted in a colour that should be brown but it's more like dark olive drab so it will stay ![]() ![]() Next is prepping the sides to paint and attach |
![]() | #78 |
sketchiness abounds... ![]() Join Date: Jun 2016 Location: Austin
That's 1 bad-ass Unimog... Love it! A canvas top will be sweet... and those panels are killer. ![]() |
![]() | #79 |
![]() | #80 |
So, I've scratchbuilt a fuel tank. I think it looked good enough but seemed a bit small. So I've copied the shape, enlarged it a bit and printed. That was some time ago but today picked it again to apply some paint and did something else see the mounts below the tank? ![]() ![]() ![]() Now it needs the metal mounts to the chassis and the fuel cap Last edited by cooper_xl; 05-15-2022 at 10:03 AM. |
Scx unimog 6x6 | JOTE | Multi Axle Rigs | 13 | 06-28-2013 07:18 AM |
6x6 unimog | davebarlow13 | General Scale Talk | 0 | 11-06-2009 08:58 AM |
scaled down portals from a unimog? | redneckwelder | General Crawlers | 6 | 05-08-2008 11:49 AM |
Unimog U500 6x6 | Wild trial | 1.9 Scale Rigs | 24 | 11-26-2007 05:37 PM |
