Go Back   RCCrawler Forums > Scale Rigs General Tech > Multi Axle Rigs
Thread: Tucker Sno Cat
Old 10-25-2017, 10:14 AM   #1
Yashua
CREEPERBOB's Avatar
Default Tucker Sno Cat
Ok, what I have is a scale drawing in 1/10th (also in 1/16th scale) scale of a Tucker Sno Cat that is a 4 tracked motivated off road vehicle.
This will be a slow build due to everything on it will have to be scratch built because of its oddity.
I does require a pair of axle housings and a transfer case of some style but that is about all as far as a regular crawler.
The steering and the track mounting points will be a project in them selves.
Anyhow,,,,, some pics to start with.
Bob
CREEPERBOB is offline   Reply With Quote
Old 10-25-2017, 10:34 AM   #2
Default re: Tucker Sno Cat
Bob.....SNO .......
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 10-25-2017, 10:39 AM   #3
Moderator
JatoTheRipper's Avatar
AWESOME! Is it done yet?
How about now?
OK I'm really anxious to see the completed project!
Old 10-25-2017, 10:40 AM   #4
Yashua
CREEPERBOB's Avatar
How about now?
Hmm,,,, me too .
Old 10-26-2017, 06:21 AM   #5
Yashua
CREEPERBOB's Avatar
So,,,, it begins
2 complete sets (4 track sets) of Heng Long German Tiger 1 track sets.
Old 10-26-2017, 08:41 AM   #6
Love the plan, however its been done and done well if you ask me. Not discouraging you, but I though you might get some inspiration. Looks like you planning on a super scale replica...
I saw this thread last year and thought it was cool.
https://www.rcsparks.com/forum/threa...t-build.41853/
Ditchrat is offline   Reply With Quote
Old 10-26-2017, 08:59 AM   #7
Yashua
CREEPERBOB's Avatar
Yea I've seen that one a couple places.
I plan a different setup as far as for steering as I won't be using Cs and knuckles.
My plan, as the original is is to rotate each pair of tracks on a large (2 1/2" O.D.) Torrington thrust bearings on turntables under the chassis.
And the fabricated tracks will resemble the originals also.
Old 10-26-2017, 11:09 AM   #8
Yashua
CREEPERBOB's Avatar
So I'm gonna need a pair of SSD D60's for housings.
Not sure of width yet so don't know which version I'll need yet.
And the original is leaf sprung , that sounds like it will be fun because I think I'm looking at some serious weight here.
Old 10-26-2017, 11:16 AM   #9
Have you seen the ssd pro44 axles?
Sent from my SM-G920T using Tapatalk
Di_Spencer is offline   Reply With Quote
Old 10-26-2017, 11:21 AM   #10
Yashua
CREEPERBOB's Avatar
Yes I have , I've got a bunch of measuring and mocking up to do before I can decide on which housings to use.
I'm thinking about the SSD scale trans/transfer case unit also.
Old 10-26-2017, 12:35 PM   #11
Moderator
I think he should use that as inspiration and as a reason to proceed with this build rather than saying "It's been done" and giving up. This is a great build, but there is room for improvement.
Old 10-28-2017, 06:40 AM   #12
Yashua
CREEPERBOB's Avatar
Yea, I'm not saying I can do it better. I'm just going to do it my way, albeit the harder way.
Body, leaf spring suspension and turntable steering will all be projects in themselves individually.
Old 10-28-2017, 10:21 AM   #13
Yashua
CREEPERBOB's Avatar
Ok, it begins.
I've got all 4 corner track motion systems coming along with 2 /1"2" O.D. thrust bearings and 20 sheets of styrene.
And I have a ton of delrin to mill chassis parts from.
Old 10-28-2017, 10:32 AM   #14
Yashua
CREEPERBOB's Avatar
And for motivation and steering duties, the traditional crawler stuff .
Old 10-29-2017, 05:33 AM   #15
Yashua
CREEPERBOB's Avatar
Leaf springs,,,,,,,,, hmm.
If ya notice in the drawings above of the turntable (it wont be plywood but delrin) and the track profile you'll notice the 4 ears on the turntable, these are the mounting locations of the spring hangers.
And if you look right at the very top of the track you'll see the leaf spring in its location.
Since this rig will be a fatty, what ya guys think would work for the leaves?
Has anyone ever used the spring from a pull start lawnmower?
Bob
Old 10-31-2017, 02:16 PM   #16
Yashua
CREEPERBOB's Avatar
Hmmm, , with higher proportion to the rear,, from what I can read about the steering it favors the rear just like a snowmobile would. Real one uses a single hydrsulic ram to steer both pairs of tracks .Interesting, very interesting.
And the suspension platforms are only attached a single pivot in the center with clamps that keep it rotating on center with very little side to side movnent.
Hmmm,,
Old 11-01-2017, 06:27 AM   #17
Bob
I've had good results with heavy duty radiator clamps. Lawn mower recoil springs seem kind of flimsy.
Sent from my HTC Desire 626 using Tapatalk
tcanin00 is offline   Reply With Quote
Old 11-01-2017, 07:24 AM   #18
Yashua
CREEPERBOB's Avatar
What are you using to narrow them?
Shears?
Old 11-01-2017, 08:23 AM   #19
Shears?
I used a fiber cut off wheel on a Dremel. I've also cut them on a band saw. Never tried shears or tin snips. Should work though.
Old 11-03-2017, 02:46 PM   #20
Yashua
CREEPERBOB's Avatar
This .
Tucker Sno Cat - Similar Threads
MG200Designs - Sno Cat MG200 2.2 Scale Rigs 16 06-22-2013 02:38 PM
Sno runner? gdhknives Chit Chat 6 02-16-2012 10:40 PM
sno,s wraith snohiker Axial Wraith 3 01-30-2012 10:32 PM
Sno-cycles DeaDShorT Chit Chat 13 01-06-2008 07:30 PM
