02-02-2023, 09:21 PM | #1 |
I wanna be Dave Join Date: Jul 2005 Location: North Idaho
| Semi Build Input...
I have a couple of new builds I am working on in expand my 1/14 semi truck and equipment collection... My next builds are based around the Bruner set below... 323287457_495578819377454_3923301728709539497_n by Scott O, on Flickr The earthmover is an RC... I am tackling the trailer first, making it compatible with my King Hauler. Between the parts I can buy along with what I can design and print, the conversion should not be that difficult. The semi has me scratching my head a bit, and this is where I need some input. I am trying to make the build cost effective, but have some indecisiveness on which way to leap... My first thought for the semi build was to find a King Hauler roller or slider, but that has turned out to be a very rare unicorn. My next thought is to use a kit King Hauler, use the parts I want, and sell the rest, but I am not sure how cost effective that will be. The only parts I really want out of a KH are the frame rails, some of the supports, some of the suspension, and a few other odds and ends, everything else I'd try to sell. • I am not crazy about the stock KH axles, and I would like this rig to be a 6x6. • I no not like the stock KH transmission, given how old the design its, it is very cantankerous compared to today's standards. I plan on using a crawler 2-speed transmission, most likely out of a TRX4. So, that just leaves the option of getting a frame and building everything up from scratch. The chassis braces, suspension mounts, body mounts, and servo mounts are all things I can design and print. Has anyone done a build like this, ground up? If so, what are the pitfalls to look out for? |
02-03-2023, 07:16 AM | #2 |
| Re: Semi Build Input...
thats a nice looking project i just started a 1/8th scale semi build ive got as far as starting to build a frame and some cad work " the cardboard kind not computer kind "to get my dimentions right ive got a sheet of styrene and the glue just came in the mail but thats as far as my scale semi exsperiance goes |
02-03-2023, 12:42 PM | #3 |
Rock Crawler Join Date: Apr 2020 Location: Drums
You may want to take a look at the axles from a Cross RC 6x6. Those are 1/12 but depending on the wheel offset you go with, you may be able to make those work. The pass-through bridge axle is the tough find for your project but maybe its worth looking at their axles.
02-04-2023, 01:49 AM | #4 |
I wanna be Dave Join Date: Jun 2006 Location: Here
Why not a TLT axle for up front, and pass through with the backside of the tlt housings
02-04-2023, 08:57 AM | #5 |
| Re: Semi Build Input... |
02-04-2023, 06:47 PM | #6 |
Newbie Join Date: Feb 2011 Location: Kennet Square PA
How about a straight axle conversion on the TRX4 6x6 rear axle? Is that a through put axle?
02-04-2023, 08:53 PM | #7 |
02-06-2023, 03:44 PM | #8 |
Rock Crawler Join Date: Jun 2013 Location: Portugal
The HG P801 8x8 measures 218.5mm wide. The axles are available separately. How wide is your truck? Different offset on wheels might work
Semi Build Input... - Similar Threads | ||||
Looking for input on my first build. | Ro@dkill | Newbie General | 2 | 10-03-2019 12:19 PM |
ground up build any input would be helpful | macclen30 | Newbie General | 5 | 09-28-2010 09:31 AM |
i need some input on my build?? | tj on 37s | Axial AX-10 Scorpion | 13 | 11-20-2009 12:38 AM |
