Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: what pinion?
Old 01-26-2008, 06:00 PM   #1
Default what pinion?
what pinion can i run with the stock axial gearing? im wanting to run something like 18-20 tooth. the 14 that comes stock is just to small.
Dickie691986 is offline   Reply With Quote
Old 01-26-2008, 07:45 PM   #2
Well I run a 17t with a 55t lathe and it works alright. Certainly not as much torque as alot prefer, but I think it offers better performance just from the wheelspeed. I don't seem to be getting stuck by lack of torque where I run so why not.
I wouldn't gear any higher than where Im at though, just volt up
Hildy is offline   Reply With Quote
Old 01-26-2008, 07:51 PM   #3
ghetto fabulous newbie
what motor are you running?
yotachump is offline   Reply With Quote
Old 01-26-2008, 08:06 PM   #4
TEAM MODERATOR
Reflection's Avatar
Thats the key question right there,cell count would be nice to.
I run a 3014 850 kv Crawlmaster with stock gearing on a 3 cell lipo and it's great. More than enough power and almost perfect wheelspeed. I've also run a 30 turn handwound on the 3 cell with stock gearing. Lacks a bit of power but the wheelspeed is perfect. Tires won't last long though
Reflection is offline   Reply With Quote
Old 01-27-2008, 01:15 PM   #5
im running the 3014 850 kv Crawlmaster with a mamba 25 and an 8 cell elite split pack
Old 01-27-2008, 04:07 PM   #6
TEAM MODERATOR
Reflection's Avatar
With that motor and stock gearing,your better off volting up to gain wheelspeed. Any taller gear and you'll start to see cogging and bad starts. I run the same thing and have tried 8 cells with stock gearing. Works nice. I tried taller gears and started to see cogging. The taller gear you run,the worse it'll get.
Add a couple 2/3a cells or jump to a 3 cell lipo. I'm VERY happy with mine on the 3 cell. If that don't get it,run a 35t on a 3 cell. Thats very fun
