03-19-2011, 09:25 PM | #1 |
Pebble Pounder Join Date: Mar 2011 Location: Nederland
| Best crawler for $200
Hello I am looking to get a new crawler I have duratrax cc. What is the best crawler for $200? Thanks |
03-19-2011, 09:36 PM | #2 |
Rock Crawler Join Date: Dec 2010 Location: Beaumont Tx!
I have a Redcat rs10 and an Axial rtc and I can say I like things about each one. The redcat was cheaper, but the radio is garbage, servos are absolutely trash, tires blow and it comes with alot of 2.5mm hardware which loves to snap off. The axial is a little more expensive, but the radio has good reception, servo has held up fine so far" alittle weak, but hey it's a rtr set up" and the tires hook up well after some weights and cutiing of foams. I broke my Redcat constantly at first and have yet to break the axial aside from driveshaft coming off outputs. I love my redcat now that it's reliable and modded up and am sure I will love the Axial just as much when I put a little $ in it.
03-19-2011, 10:43 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
Are you looking for a ready to run crawler or do you have a radio, batteries, charger etc? In my opinion for the money the AX10 RTC package is one of the better values out there. Tons of aftermarket support and proven durability. It's going to run you around $250 shipped so I would look at increasing your budget a little or keeping your eye on the classifieds once you can view it. The Venom Creeper is another option you should consider but it's a kit so you will need to add electronics which is probably going to end up being more expensive than the AX10 but be able to keep it in budget with some lightly used gear.
03-21-2011, 09:08 AM | #4 | |
Rock Stacker Join Date: Feb 2011 Location: FrayedEdgeofSanity
http://www.rcuniverse.com/magazine/a...rticle_id=1201 | |
03-21-2011, 09:22 AM | #5 |
Rock Crawler Join Date: Mar 2008 Location: 920 Valley of the Fox
| x2! save $50 more bux and get the ax10 RTC. |
03-22-2011, 08:39 AM | #6 |
Rock Stacker Join Date: Mar 2011 Location: RI
| I took this advice! I tried to price out a Venom and using the cheapest parts it came out about the same. I now have the Ax 10 on the way,for the money it seems to be a great place to start.You can build it into an $800 comp crawler if you want, but get started at $250. |
03-22-2011, 10:09 AM | #7 |
Newbie Join Date: Mar 2011 Location: Virginia newport news
i have that truck ,, its great . very good starter climber . get new tires , and some wight up front and she does wonders . also you will want to remove the battery from the top ... get it down low . this sight has alot of great tips for that truck . is there a hobby store near you ? do you know how to solder ?
03-22-2011, 10:36 AM | #8 |
| you will see in this pic , that i took the skid plate off and moved the rear brace bars to the inside of the truck . also if you get some 40/40 all thread and some carbon fiber tube that the 40/40 rod will slide into. ( sorry not sure the size of the carbon fiber tube , then get you some aluminum tubing size 7/32 x .014 or ( 5.56mm x .355mm ) . and then get some ball ends . you can now make metal brace arms instead of the plastic ones that come on the truck . the stock ones work , but you will see them flex alot , and they also cause tork twist . to make them cut the threaded rod , the carbon rod and the aluminum rod all the the correct length . ( dont forget to measure the ball ends in with the length ya need . i just layed the stock bars on the table and layed out the ball ends and measured between them to get my size for cutting . also dont for get the threaded rod stick out about 1/4 inch past the new rods ya cut , so that the ball ends will screw on to them. then screw one ball end on the threaded rod , then slid the carbon tube over the threads then slide the aluminum tube over the carbon rod , fit's like a glove , then screw on the other ball end , and wala you have a metal ( carbon braced ) brace bar . if you want to do like i did , get some bic pens and cut to size and slide over the aluminum . seams like over kill , but the plastic slides over the rocks easier and the plastic pen tubes spin around the metal helping slip you off the rock . i think buying everything i spent like 22 bucks . but i did my front steering and linkage bars , along with all 4 of the bottem brace bars . hope this help's . if ya want pm me and i have alot of tips with this truck . oh yea hear is mine . |
03-22-2011, 02:53 PM | #9 |
Rock Stacker Join Date: Jan 2011 Location: Carencro
Where can one get this AX10 RTC kit?
03-22-2011, 03:23 PM | #10 |
Quarry Creeper Join Date: Jun 2008 Location: Central KY
RPPHobby.com and TCSCrawlers.com to name a couple.
03-22-2011, 03:38 PM | #11 |
I got mine at amainhobby.
03-22-2011, 03:39 PM | #12 |
Thanks. Is an AX10 RTC the best bang for the buck in that price range? I've read some saying that they would just use the axles and trans and piece one together if they had to start over. |
03-22-2011, 03:51 PM | #13 |
For an off-the-shelf rtr crawler, yes it is...but you will eventually want to upgrade a few parts here and there and change some things around. Put it this way, of all the RTR crawlers out there, for that price range, I wouldn't consider anything other than the AX10 RTC.
03-22-2011, 03:53 PM | #14 |
Could I build an "AX10" with the upgraded parts for the same $$$$? If so i'd be interested to here what everyone considers must have upgrades for an AX10. I know anything can get out of hand but i'd sure like to waste the least amount of moneyt that I can while getting started. |
03-22-2011, 04:00 PM | #15 | |
Possibly, especially if you got some of the parts used. Must have upgrades would be aluminum knuckles and C's, along with either MIP or Traxxas Stampede driveshafts. Some may also suggest better outdrives for the tranny, but I've never had any issues with mine. It largely depends on if you want to assemble your own, assemble a kit, or buy a RTR/RTC and run it, then tear it down and rebuild it with upgraded/replacement parts. | |
03-22-2011, 06:23 PM | #16 | |
I think you could come pretty close as long as you get a good deal on the tranny and axles and fab some of your own parts. Here's what I did with my RTC right out of the box. forbid89's rig in progress Aside of buying some tools I didn't have I spent very little making my own links out of brake line and delrin, as well as link plates from scrap aluminum. Start watching the classifieds and see if you can score a deal on parts. | |
03-22-2011, 07:36 PM | #17 |
You can build a ax10/scx10 for pretty cheap if you 1. have access to the clasifieds section. (you'll need to wait your 30 days/30 post or buy a star. Buying a star is the best $20 you'll spend on your crawler) 2. A paypal account with money in it. 3. Ebay 4. Patience. Heck, you could practally build a crawler from RPP's salvage yard section. They had Axial axles on there earlier today for $45 bucks I think, now they're gone. http://www.rpphobby.com/category_s/407.htm or, you can get some really good deals in the classifieds section here. Theres always upgraded trucks (a lot of ax10's) for cheaper then a new rtr for sale. If you go that route you gotta be quick! You need to check it a few times a day and have money in your paypal account. Most sellers here are really good about price. I recently bought a kinda rare item here for $50, there's a used one (only 1) on ebay right now for a buy it now price of $130! |
03-22-2011, 07:51 PM | #18 | |
http://www.rccrawler.com/forum/showthread.php?t=214810 | |
03-23-2011, 06:33 AM | #19 |
Thanks for all the info! I'm thinking that I am going to try and build one in that price range. I have a good friend that has a built AX10 so I can look to it for a solid parts list since I really like the way that it works. |
03-23-2011, 09:52 PM | #20 |
Newbie Join Date: Dec 2010 Location: Overgaard
Get a used venom creeper, for the money you cant go wrong.
