12-18-2012, 03:35 PM | #1 |
Newbie Join Date: Jun 2012 Location: Crosby
| Help with maxstone 10
What's the best setup for the best crawling experience with the exceed max-stone 10. already got panther tires, deans plugs, lipo battery, good esc and reciever, and average remote. Stock axles, stock shocks (stiff in the rear-soft in front), plastic axle c's and knuckles. Rear lockouts also.
12-18-2012, 04:23 PM | #2 |
Quarry Creeper Join Date: Nov 2011 Location: dark corner
| Re: Help with maxstone 10
Heres the maxstone 10 i just modded for a friend and it works really well And here is after i put it on a new chassis. Axle wise there almost the same as an ax-10 so you could buy ax 10 overdrive and underdrive gears for it and get you some narrower wheels and maybe some hot bodies sedona tires and you also could buy an aftermarket ax10 chassis and be set to go. Its really a good cheap platform to build a heck of a good crawler! |
12-18-2012, 04:43 PM | #3 | |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| Re: Help with maxstone 10 Quote:
12-18-2012, 04:44 PM | #4 |
Newbie Join Date: Dec 2011 Location: Prescott valley
get the body as low as possible, add wheel weights (made the axles weaker on mine) put bent lower links and remove the bumper and shave the posts. get the battery as low as possible |
12-18-2012, 05:09 PM | #5 |
| Re: Help with maxstone 10 the bent links i got from https://www.****crawlers.com/ax10-sp...24_238_56.html, the roll cage i got from integy and the losi claws on narrower redcat rs10 wheels i got from my LHS where i mount my batery |
Help with maxstone 10 - Similar Threads | ||||
Maxstone 10 help | crawlerbeast | Newbie General | 23 | 01-19-2013 09:43 PM |
maxstone 10 | jeremyfowler33 | General Crawlers | 3 | 12-21-2012 04:49 PM |
Maxstone 10 Help | kidfrost44 | Newbie General | 4 | 12-05-2012 08:16 PM |
My MaxStone 10 | StreetShaker | Newbie General | 6 | 10-31-2012 03:12 PM |
Maxstone 16 help.. | maxstone16 | General Crawlers | 2 | 09-02-2012 04:55 PM |
