12-26-2012, 06:07 PM | #1 |
Newbie Join Date: Dec 2012 Location: Texas
| Help me choose a battery and charger
First off i have searched and have a good basic knowledge of batterys but just couldnt find the answers i needed. I just got my first rc crawler a few days ago and love it! its a max stone 10. Im ready to upgrade the battery to get longer run time and shorter charge time. I understand lipos seem to be the way to go but it seems like a decent nimh would work fine as well. The battery that the rig came with is a 7.2v 1800 mAh. I found this package deal that has 2-7.2v 3800mAh batterys and a charger that charges in 1-2 hours Amazon.com: Two 7.2V 3800mAh High Power NiMH Batteries with A 7.2V-12V Smart Charger: Toys & Games Would this do okay? Could someone suggest a better option? im open to a lipo set up if they arent to outragously priced. |
12-26-2012, 07:59 PM | #2 |
| Re: Help me choose a battery and charger
can pretty well guarantee you those batteries won't be charged in any less than 2 hours 15 minutes each. The batts would probably work quite well for you, but there's better and cheaper chargers out there.
12-26-2012, 08:31 PM | #3 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
Why not go lipo?
12-28-2012, 04:18 PM | #4 |
look into the thunder ac6, decent price about 50 bucks and does a crap load of different batts. |
12-28-2012, 04:27 PM | #5 |
Rock Stacker Join Date: Dec 2012 Location: Fremont
I like Turnigy, I 'm sure there is better out there but, for me this does the trick - Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories (USA Warehouse) And get a Lipo!!! |
12-28-2012, 04:32 PM | #6 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
i use the onyx 235 charger it dose them all with great results an comes with a bunch of adapters in the box
12-28-2012, 07:31 PM | #7 |
I use a turnigy 200 watt charger and computer supply I converted into charger power supply. Less the 60 bucks into hole system. A 5000 math lupo takes 20-30 minutes to charge at 2c which is 10 amps. 2200 batteries take 8-15 minutes. I try and buy lipos with a charge rate of 4c or higher. NiMH just plane takes forever no matter the charger used |
12-29-2012, 07:10 PM | #8 |
It's hard to beat the Thunder AC6 for the money. Charges almost anything and comes with a bunch of different adapter harnesses. For batteries you'd likely be best served with cheapo 2200mah 30C or 40C rated 2s packs. The better budget options are from Turnigy or Fly Sky. They'll ditch a lot of weight compared to the NIMH stick packs. The smaller size also opens up more mounting options. |
12-29-2012, 08:19 PM | #9 | |
| Re: Help me choose a battery and charger Quote:
12-29-2012, 08:29 PM | #10 |
Just found this battery. wow 10000mah!! that must last 3 hours! http://www.hobbypartz.com/98p-40c-10...se-direct.html What about this battery? it seems to have some good reviews. would it work for me? http://www.hobbypartz.com/98p-40c-50...-hardcase.html what would the charge time be? Last edited by blake22; 12-29-2012 at 08:42 PM. |
12-29-2012, 10:53 PM | #11 |
I bet close to an hour runtime Bout an hour to charge at 10 amps bout half hour at 20 amps. |
12-30-2012, 01:55 AM | #12 | |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
--Dan | |
12-30-2012, 08:15 AM | #13 |
^^ lol so how long will it really take to charge the second lipo i posted? Also how long will it last? again.. can you have too much battery for your esc? as long as i stay with 7.2v i should be okay right? i could have a 400c the esc doesnt care. thats how i understand it but please correct me if im wrong |
12-30-2012, 11:31 AM | #14 | |
12-30-2012, 03:13 PM | #15 |
Thats weird.. i cant see the orginal post only the quote that trubble made? anyways.. After running the truck a few more times for about an 45min to an hour. I dont think i need any more run time. If i get the AC6 will it charge my current battery faster? |
01-01-2013, 01:19 PM | #16 |
| Re: Help me choose a battery and charger Faster than what? Don't know what you're currently using for a charger. IIRC, your current batts are 1800mAh? The charger you linked in your first post will charge them in about an hour (@ 1.8 amp setting). Charging at any more than that will likely damage them. So in that case, no, the AC6 won't be any faster. But if you ever go LiPo and/or get anything larger than 1800mAh, then yes, the AC6 would be faster than the one you linked. |
01-01-2013, 03:01 PM | #17 |
Rock Crawler Join Date: Oct 2011 Location: Corona, CA
| Re: Help me choose a battery and charger |
01-02-2013, 08:02 PM | #18 | |
01-02-2013, 11:52 PM | #19 |
Oh Geez! Yes, the AC6 will have you charged up in an hour.
01-04-2013, 08:57 AM | #20 |
Thnaks for helping me and sorry for all the stupid questions!
Help me choose a battery and charger - Similar Threads | ||||
Battery/Charger ?? NiMH's w/ NiCD Charger ? | 56effie | Electronics | 5 | 10-31-2014 01:23 PM |
Help trying to choose a Lipo battery | craddock35 | Newbie General | 10 | 07-23-2010 05:06 PM |
choose my next battery... | syber70 | Electronics | 25 | 02-28-2009 06:03 PM |
which tuber to choose and battery.. | Daddydancool | Axial AX-10 Scorpion | 19 | 03-13-2008 01:46 AM |
Ultimate BATTERY THREAD How do you choose | toy4crawlin | Electronics | 11 | 06-08-2007 05:22 PM |
