01-08-2013, 01:41 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Julian, CA
| Gear Mesh?
Wraith, stock motor. What kind of gear mesh? Tiny bit of play? I'm familiar with Nitro gear mesh, not electric.
01-08-2013, 01:50 PM | #2 |
Quarry Creeper Join Date: Mar 2012 Location: Roseburg
| Re: Gear Mesh?
im not too familiar with nitro meshes if they are any different. for 48p gears you do want a little play. much less play then a 32p gear. |
01-08-2013, 05:30 PM | #3 | |
| Re: Gear Mesh? Quote:
Take a narrow strip of inkjet/copier paper and put it between the pinion and spur gear. Press the gears together and tighten down the motor screws. Once the motor tighten down, you should be able to pull the paper out and the gears will rotate as you pull. If it comes out without rotating the gears then you need to press harder as you tighten the motor screws. If you can't get the paper out then the mesh is too tight. For 32p gears you can double up the paper and get the correct mesh. | |
01-08-2013, 06:02 PM | #4 |
Newbie Join Date: Sep 2005 Location: mooresville
| Re: Gear Mesh?
For the stock gears in the wraith, 48p i believe, you can also set the gear mesh tight with a pinion gear one tooth more than you plan to run. Tighten the motor up with that pinion on it. Then remove that pinion and place the next tooth smaller pinion on. Gear mesh should be good to go then. Later.
01-08-2013, 06:15 PM | #5 |
Pitch doesn't matter, a tick of play is needed. That tick can be relative.
01-09-2013, 05:20 AM | #6 | |
Additionally, some gears are NOT concentric, thus as you rotate the gears, the mesh gets looser & tighter. Once it's all locked down, recheck in ~6 spots around the spur gear to see the mesh. You "almost" don't want to see the gears move relative to each other, but you don't want them too tight. Too tight can wear on the motor bearing/bushing as well as make the motor run warmer. Too loose can lead to stripped gears. | |
01-09-2013, 12:24 PM | #7 |
True about the feel. I really learned feel on my old nitro savage, the tvp's didn't allow one to see the gear mesh or put a slip of paper in easily. "My" tick works for me.
01-09-2013, 08:09 PM | #8 |
Pebble Pounder Join Date: Dec 2012 Location: Missouri
| Re: Gear Mesh?
I always used the paper trick, until I got the "feel" for it. Never really had a problem.
01-09-2013, 10:05 PM | #9 |
Quarry Creeper Join Date: Aug 2012 Location: Warrenton
| Re: Gear Mesh?
been using the paper method for 20 yrs... always perfect and never had any stripped pinions or spurs
01-09-2013, 10:50 PM | #10 |
Rock Stacker Join Date: Dec 2012 Location: Fremont
| Re: Gear Mesh?
I like using the paper, good mesh every time. But more importantly I think is to allways put some blue locktight on the set screw that holds the pinion.
01-10-2013, 03:53 PM | #11 |
| Re: Gear Mesh?
OK. Same as Nitro. I was thinking about Loctite. Will do! |
01-11-2013, 11:25 AM | #12 |
| Re: Gear Mesh?
For a newb the paper trick is a great way to learn how it should look. Once you do it a few times the "feel" method is good. I basically tighten it down so they are bottomed out, and then pull the pinion back just enough so that when I hold the pinion stationary and jiggle the spur back and forth I can feel just a touch of play. And by a touch, I mean very very little, you just want to feel that there's a tiny gap. I do this for 48p and just a little more snug for 32p.
02-05-2013, 11:21 PM | #13 |
Pebble Pounder Join Date: Jan 2013 Location: San Diego
Some gear are not concentric? That might explain my latest issue. Installed a 48P 87t team associated spur and an 11T Novak pinion. It is nice and low. Super creepy slow. But, it is much louder now. Not the motor revving higher, but the gears. I put a little grease on the teeth and that's wasn't it. I set the mesh with a little play by the feel and see method. I flipped the truck over and observed a "lump" in the drivetrain. As it idles, the rear axle will occasionally jerk. I tried compressing the suspension and it still occurs. Is this likely an inconsistent pinion or is there something else to look for? |
02-06-2013, 12:11 PM | #14 | |
Also check for dings/etc. in all the gear teeth. You may have a damaged/bent tooth that is creating the "lump" you see. You may be able to find it by spinning the spur by hand (while it's engaged with the pinion) to see if you see if it's a common spot on the spur when it "lumps". | |
02-06-2013, 12:20 PM | #15 |
I've found that it helps me to disconnect the drive shafts from the trans and slowly pull the throttle to eye what's going on. If there doesn't seem to be anything serious going on, let it wear itself in.
02-06-2013, 12:57 PM | #16 | |
Pebble Pounder Join Date: Nov 2011 Location: Central Kansas
02-07-2013, 02:37 AM | #17 | |
Quarry Creeper Join Date: Sep 2012 Location: middle of nowhere
I've found that the more drastic the tooth difference between two mating gears the louder the wine due to the geometry of the gear teeth. I went to a 11/60 on one of my summits, it's drastically noisier than the other with stock 14/60 gears. I assure you both are meshed correctly. As for the jerking axle, attention is probably needed. Sent from my iPhone using autocorrect Last edited by happymachinist; 02-07-2013 at 02:40 AM. | |
Gear Mesh? - Similar Threads | ||||
Gear mesh | mud-sweat-gears | Tamiya XC/CC01 | 4 | 08-15-2012 10:56 AM |
Bad Mesh on bevel gear and diff gear out of the box? | Elliott000 | Axial SCX-10 | 3 | 08-19-2011 06:37 PM |
gear mesh | Losi man | Losi Mini-Rock Crawler | 3 | 10-03-2009 06:43 AM |
bevel gear, ring gear mesh | rocksteadily | Tamiya TLT Crawlers | 5 | 05-09-2009 12:04 AM |
ax-10 gear mesh | goblin79 | Axial AX-10 Scorpion | 4 | 02-13-2009 10:22 AM |
