02-17-2013, 12:53 AM | #1 |
Quarry Creeper Join Date: May 2006 Location: san diego
| over/under gearing question?
is axial scx10 axles the only ones that offer the over drive gear ratios? if not which others ? i searched rc4wd site and googled but axial seems to be the only ones. thanks in adavance-arick |
02-17-2013, 02:47 PM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: US
| Re: over/under gearing question?
As far as I know they are the only ones to offer varied gear ratios for the diffs. You can accomplish something similar on the TF2 as 'Dready' showed his brilliant ingenuity. Search on the TF2 section under tips. You could do this on any truck in theory. What he did was to switch the input and output use on the transfer case. If the input is reduced down for the final drive to the F/R wheels, you can switch it so that the motor drives a high input and then you use a low for the rear and high for the front. Makes no sense, right? Check the thread if you're interested. All the best |
02-18-2013, 07:49 PM | #3 |
thanks for the reply, i kinda was hoping to hear the rc4wd alum axles can swap gear ratios. Then again axial's are cheap and every option is there for them. thanks again.-arick |
11-07-2013, 06:03 PM | #4 |
Newbie Join Date: Jul 2010 Location: Bend
My Wheely King axles have over/under gearing options. Out of the nitro RS4 and Savage I believe. I just did mine and it works great.
11-07-2013, 07:52 PM | #5 |
Rock Crawler Join Date: Nov 2010 Location: Ohio
| Re: over/under gearing question? If you want aluminum, both integy and VP make aluminum axels that use Axial gears. That said, all Axial axels use the same gears.
over/under gearing question? - Similar Threads | ||||
gearing question | krank22 | Axial Wraith | 1 | 01-13-2013 04:55 PM |
Gearing question | transambill | Axial Wraith | 6 | 01-29-2012 07:04 PM |
Gearing question??? | shmangi | General Crawlers | 15 | 03-31-2011 04:21 PM |
Gearing Question: | xxgg | Axial SCX-10 | 1 | 06-06-2010 08:55 AM |
another gearing question! | luckyNum13 | General Crawlers | 2 | 05-18-2005 05:28 PM |
