12-16-2013, 06:01 PM | #1 |
Rock Crawler Join Date: May 2013 Location: plains
| more winch questions
Hey all. I jus had to replace my motor in my winch already well replaced the gears so after research I found on the side away from the motor doesn't have a bearing or anything to help spin it. Its jus a brass bushing that rides in there. I believe this brass piece is the culprit that made it hard for the spool to spin easy and chewed up some gears. Has anyone replaced that brass piece with a bearing if so was it a common bearing or? I guess I should mention its a bulldog winch.
12-17-2013, 03:02 PM | #2 |
| Re: more winch questions
No one?
12-17-2013, 07:15 PM | #3 |
Pebble Pounder Join Date: Oct 2013 Location: Stockton
Have you thought about going with a servo winch instead
12-17-2013, 08:07 PM | #4 |
Yea later down the road when I can afford a new 3 channel remote. The bulldog winch I have is the wireless remote one.
12-17-2013, 08:25 PM | #5 |
RCC Addict Join Date: Oct 2012 Location: Norcal
I'm running a Bulldog on my 3rd channel and wasn't to happy with the performance. My truck is a pig though. I got rid of the stock controller and went with a HeyOk relay controller and WOW! It will easily lift my truck off the ground now. Now the weak point is the winch (gears and motor). I plan on picking up the new one from RC4WD that can take 3S when it comes out: RC4WD 1/10 Warn 9.5cti Winch I have a new Savox 1230 coming for my Crest and plan on using the slightly used 1230 as a servo winch. I don't think that bushing makes that big of a difference really. |
12-18-2013, 11:18 AM | #6 |
It jus seems like it sticks on that side. Maybe I'll get like some silicon lube spray and see if that helps. I didn't ruin the first set of gears pulling anything jus rewinding aime new winch line on. My rigs a pig too I'll eventually go to a three channel radio and a servo winch but jus wondering if anyone had a remedy for the bulldog one for now.
12-18-2013, 04:59 PM | #7 |
Newbie Join Date: Nov 2012 Location: Tampa
I put a drop of bearing oil on the brass bushing and it works great now.
12-18-2013, 07:30 PM | #8 |
How does that work with dirt and debris? Does the oil atrack dirt and stuff?
12-19-2013, 12:40 AM | #9 |
Pebble Pounder Join Date: Nov 2013 Location: Corsicana
Does anyone know of a good servo winch build thread I can't find one. Don't mean to hijack bud! |
12-19-2013, 10:59 AM | #10 |
| Re: more winch questions Search it!!!! There's a few if you use the search function!!! |
12-27-2013, 08:51 AM | #11 | |
Newbie Join Date: Dec 2013 Location: indonesia
| Re: more winch questions Quote:
Can you put bulldog winch with stock controller to airtronics mt-4 3rd channel? | |
12-28-2013, 10:00 PM | #12 |
Newbie Join Date: Nov 2010 Location: West Jordan
Mine did the same thing I put new motor and gear set greased it has worked With no problems since |
more winch questions - Similar Threads | ||||
rc4wd winch questions | cameraman | General Scale Talk | 8 | 11-24-2011 08:29 AM |
winch questions | ratmloud | Electronics | 1 | 04-04-2010 06:57 AM |
winch questions | LS1Armyboy | General Scale Talk | 5 | 01-25-2010 05:36 PM |
Winch questions | hitman46mod | Electronics | 3 | 11-26-2009 09:09 AM |
winch questions and answers | rckjeep | Electronics | 30 | 01-26-2006 04:17 PM |
