02-16-2015, 10:03 AM | #1 |
Newbie Join Date: Feb 2015 Location: Belgium / Leuven
| SCX10 RTR - Short or Long Wheelbase ? Which is best ?
Should I buy a Scx10 with a shorter wheelbase (like the Dingo Kit) or with a longer wheelbase (like the Power Wagon) ? Thanks in advance. |
02-16-2015, 08:49 PM | #2 |
Quarry Creeper Join Date: Oct 2012 Location: Malang, Indonesia
| Re: SCX10 RTR - Short or Long Wheelbase ? Which is best ?
short or long it comes to your taste in the look of the bodies it comes with.. shorter WheelBase will benefit in tigher turn, the longer ones in stability (I guess, CMIIW) but SCX10 does comes with the G6 version which puts it in the middle of the two.. your choice, have fun choosing then |
02-17-2015, 01:40 AM | #3 |
Thanks! I will think about it
02-17-2015, 04:46 AM | #4 |
Newbie Join Date: May 2008 Location: lake odessa
It is not too difficult to adjust the wheelbase either. The driveshafts have some adjustment in them so changing links can help
02-18-2015, 02:29 PM | #5 |
Newbie Join Date: Feb 2015 Location: Vonore,TN
Yeah, I'm pretty sure changing Wheelbase is easy .. I'd go with a G6 or a honcho, but its up to you. Kinda biased because I have a Honcho, but hey..
02-18-2015, 04:25 PM | #6 |
Rock Crawler Join Date: Jan 2014 Location: Granite Falls, WA
If you do some searching on "short wheelbase" you'll find quite a few threads where pro's & con's are discussed. With that being said, I'll add that it also depends on what terrain you plan on wheeling your truck. If you'll be going up many inclines, a longer wheelbase is better, but if your terrain is more level, with rocks and tree roots, a short wheelbase is better, because of the increased breakover angle. I have both a 12.3" wb SCX10 and a 10.75" wb SCX10. With good weight distribution, I've made my 10.75" wb rig fairly capable at climbing uphill, as long as there aren't many rocks to navigate, but a winch will help with that. It excels on level ground, crawling over tree roots and creek rocks. My 12.3" rig will go up steep mountain trails, crawling over rocks at pretty good angles. I enjoy having the two sizes, personally.
SCX10 RTR - Short or Long Wheelbase ? Which is best ? - Similar Threads | ||||
Short vs Long wheelbase? | maddmaxx46 | Newbie General | 17 | 05-31-2014 07:16 PM |
Long vs short wheelbase | soundmaster | Axial SCX-10 | 11 | 10-29-2013 08:39 PM |
scx10 rubicon rtr wheelbase reduction | belvidere22 | Axial SCX-10 | 3 | 08-08-2013 09:11 AM |
Short Wheelbase Concept | flowingmotion | General Crawlers | 15 | 07-05-2010 08:51 PM |
19" WheelBase to long? | team-nyke | Tamiya Clod Buster | 2 | 12-19-2004 02:14 PM |
