04-19-2015, 06:24 PM | #1 |
Rock Stacker Join Date: Feb 2015 Location: Frankfort
| Scx10 deadbolt, steering but no throttle
Ok just ordered 1.9xls new metal horn and installed them today, went out to a course we do. Wasn't impressed with the tires, seemed like I lost power. Made it about half way though the course we usually do, and it started acting like the battery was diying. Thought well this sucks those tires drained my battery. I thought there is no way it drained that fast. I hit the throttle a couple more times and it would go for about 3 ft then stop. Then it woul have no throttle and only steer. I swapped my wife's battery into my deadbolt and still had steering and lurched forward a few times but then would stop. When we got home, I tested the motor, and the motor spun fine. Did I somehow burn up the esc?
04-19-2015, 08:06 PM | #2 | |
Quarry Creeper Join Date: Oct 2012 Location: Malang, Indonesia
| Re: Scx10 deadbolt, steering but no throttle Quote:
switch to my younger lipo, it solves the dead on track thing.. I guess I didn't properly charge & used the old ones.. or may be it was just time for me to get another lipo set but, try swithcing out you old ESC to a spare if you have one.. just to make sure it's the ESC's fault | |
04-19-2015, 08:38 PM | #3 |
Both batteries are fairly new, the wife and I both have Lipo reaction 5000 mah, maybe a month old with 15 charges on it. I have a dynamite prophet sport Lipo charger ratted at 3a. I. Plug in the charger turn it up to 3a then plug in battery. When beeps fully charged, I hold the stop button and remove battery. I swapped her battery into my truck but it still did the same thing?
04-19-2015, 08:49 PM | #4 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Did you over tighten your wheels and cause binding? That could case what your described. Just a thought
04-19-2015, 09:05 PM | #5 |
| Re: Scx10 deadbolt, steering but no throttle |
04-20-2015, 03:27 AM | #6 |
Rock Stacker Join Date: Jun 2010 Location: Goodyear/ West Phx
I'd try two more things. One, make sure the lipos are good. Based on description, it's unlikely they're bad, but make sure they power a different vehicle. Next, use Axials steps to program the ESC. Maybe something internally went haywire (Axial Racing - Axial AE-2 ESC Set-up and Programming). If neither of those things work, it really could be the ESC. If there was binding or something causing drag, the ESC could have overheated.
04-20-2015, 09:12 AM | #7 | |
04-20-2015, 01:45 PM | #8 |
I can't get the esc to recalibrate. The throttle trim is all the way down. I turn on reciver, hold full throttle, turn on esc it beeps twice then immediately the esc just blinks red. No more beeps, until I let of throttle. Then it will beep once and red light goes off. I then have throttle again.
04-20-2015, 07:05 PM | #9 |
Newbie Join Date: Apr 2015 Location: Vancouver, WA
I'm kinda having the same problem with my AX10 deadbolt, but I think it has the same esc as the sx10 deadbolts, but o ly difference is when I turn mine on, I only get steering control no throttle. And now, can't even re program the esc. My son's sx10 deadbolt has no problems at all, and he bashes it into everything..lol he's o ly 6yrs old.
04-20-2015, 07:33 PM | #10 |
Call hobby Co and speak with tec support
04-22-2015, 11:10 PM | #11 |
Quarry Creeper Join Date: Feb 2015 Location: burley
I'd just swap out the esc sounds like some issues I've had in the past with the esc. Stock axial esc is only 40ish bucks so not to bad.
04-23-2015, 01:00 AM | #12 |
Newbie Join Date: Sep 2014 Location: Perth, Australia
Tried to re-bind the receiver? Could be an issue on that side?
Scx10 deadbolt, steering but no throttle - Similar Threads | ||||
Help. Throttle controlling throttle and steering | andneverexhale | Electronics | 6 | 08-21-2014 07:46 PM |
Steering no throttle | moejean | Axial SCX-10 | 9 | 03-31-2013 12:33 AM |
Steering but no throttle | 2JSC | Electronics | 16 | 05-09-2010 12:18 AM |
Steering induced throttle- | mckenzies | Electronics | 6 | 05-06-2010 09:41 AM |
