09-15-2015, 01:22 PM | #1 |
Newbie Join Date: Aug 2015 Location: middleofnowhere
| need some advice for shocks
im trying to build up my beast 2, but i found the articulation to suck. im trying to put 100mm shocks on so i can lift and slide the rear axles apart to fit better tires on. so the question is where can i get good 100mm shocks from that are about 12mm(this even might be too big) or less wide, im looking for performance over looks. also does any one know if the triton 2spd transfer case fit in this thing? |
09-15-2015, 02:34 PM | #2 |
Quarry Creeper Join Date: Feb 2015 Location: Norway
| Re: need some advice for shocks
Have you looked at rc4wd shocks with inner springs? RC4WD Superlift Superide 100mm Scale Shock Absorbers (2) RC4WD 2x The Ultimate Scale Shocks 100mm (Silver) Not sure if this helps, but both shocks a od less than 12mm. |
09-15-2015, 02:57 PM | #3 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
I'm a not sure about the Triton. But i know Asiatees sells these Boomracing shocks that are really affordable and aslo perform pretty decent.
09-15-2015, 03:38 PM | #4 |
I heard the ultimate scale shocks weren't all that good. That's what I was originally going get
09-15-2015, 05:36 PM | #5 |
these woud fit also, seems like there is a good selection of shocks with a od less than 12mm. RC4WD Dual Spring 100mm Scale Shocks |
09-15-2015, 10:20 PM | #6 |
i think im going to try for wheel wideners. the only reason i need to use narrow shocks is because the wheel hangs up on the spring under articulation. now i just need to find some 4mm wideners
09-15-2015, 10:48 PM | #7 |
Rock Crawler Join Date: Nov 2014 Location: Grimcity, On
That's not supposed to happen. Pictures worth 1000 words bud Sent from my Nexus 5 using Tapatalk |
09-17-2015, 03:25 PM | #8 |
They are rubbing because I swapped to proline power strokes
need some advice for shocks - Similar Threads | ||||
Advice shocks upgrade SCX10 TR | moldorf | Axial SCX-10 | 4 | 02-12-2010 10:59 AM |
Need advice on wheel wideners and shocks. | ToTheMAXXcrawler | Tamiya TLT Crawlers | 19 | 02-03-2010 12:25 PM |
Need shocks-advice please | Tbone | Newbie General | 3 | 01-22-2010 02:22 PM |
front shocks & tummy tuck advice | krawlinCJ | General Crawlers | 1 | 01-30-2007 05:50 PM |
