11-22-2015, 09:12 PM | #1 |
Newbie Join Date: Nov 2015 Location: port alberni
| servo setup
I have been using the search function and must not be searching the right thing. Keep getting look at the pinned servo setup in the forum. Everytime I search I keep reading about others with different problems and responses about the pinned setup thread. Can someone post a link. I setup my servo and it always buzzes like its trying to find centre even when I driving it and steering.
11-23-2015, 03:03 PM | #2 | |
| Re: servo setup Quote:
11-23-2015, 04:03 PM | #3 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: servo setup |
11-23-2015, 06:52 PM | #4 |
| Re: servo setup
pics help too
11-23-2015, 09:16 PM | #5 |
| Re: servo setup
scx10 hitec 7955tc
11-23-2015, 09:20 PM | #6 |
Quarry Creeper Join Date: May 2009 Location: India
| Re: servo setup
Are you using a BEC to power the servo?
11-23-2015, 09:23 PM | #7 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| Re: servo setup
Digital servos usually buzz, sounds normal to me.
11-23-2015, 09:24 PM | #8 |
| Re: servo setup
Noise is normal. It's when it doesn't work should you then worry.
11-23-2015, 09:27 PM | #9 |
tg not ts and I dont know how to attach an image no I am not Last edited by THX_138; 12-14-2015 at 04:25 PM. Reason: Posting minute apart |
11-23-2015, 11:16 PM | #10 |
Rock Crawler Join Date: Aug 2013 Location: Norway. Bodø city
| Re: servo setup
I think the hitec servos make more noise than savox and futaba servos.. I have learned to like the servo noise from my 7950,, my 7980 does not make as mutch noise as my 7950,, But I have always used hitec,, (never change a winning team) |
11-24-2015, 06:02 AM | #11 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: servo setup If you're not running one of the very few ESCs with a 5a+ internal BEC, highly recommend the BEC with a Y harness so it powers servo only, and set at 6v or 7.4v. Servo and ESC both will perform better and last longer. If all you're hearing is some noise but the servo isn't moving back and forth on its own, you're probably fine. If servo moves back and forth on its own trying to find center, then you have a problem and should send it in for repair. |
11-24-2015, 06:57 PM | #12 |
| Re: servo setup |
11-24-2015, 10:20 PM | #13 |
| Re: servo setup good to know I had a savox before that came with the rig. lhs told me this one is one of the best and will last a long time. I didnt research because this hobby has turned me into a little kid and as soon as mine quit working I took it apart and couldnt fix it and just went to the shop and he gave me a few options and I just wanted to go back crawling.
servo setup - Similar Threads | ||||
Servo setup | mclunk | Axial SCX-10 | 4 | 02-14-2015 10:34 AM |
Servo winch setup | zjguy721 | Axial Wraith | 7 | 09-30-2014 07:41 PM |
My R2D servo setup | zumzum5150 | Scale Accessories | 2 | 07-23-2008 02:01 PM |
new need help with how to setup a servo | freekycrawler | General Crawlers | 2 | 09-27-2005 08:17 AM |
Dual servo setup?s | avsno2000 | Electronics | 3 | 09-12-2005 10:28 AM |
